How much trailer to buy?
I'm taking some time off work this summer, and want to drive around the US and hit up as many tracks as possible. I've been looking for a 24' enclosed aluminum trailer, and a half ton to tow it. I have absolutely no experience with trailers, so thought I'd ask.
How much trailer should I buy? Do we all really need all those cabinets, electronics, etc?
Ideally I'd like something that I can sell for not a great loss in a year or two (not sure if I'll do enough track days post break to justify the cost), and I would like something that I can comfortably tow with a half ton.
I could probably write 4 pages in this but i think the most important item is the up size the axles. The base trailers will be 2-3500lb axles and that will probably handle a porsche but u r approaching its usable limit.
If u upgrade to a 5k axle u get bigger breaks, bearings and higher tire rating options. All these things give u better relability for longer.
My 24' steel framed featherlight has 7k axles and load range e tires. I never worry about being over weight.
If you're dragging it all over the countryside, and not just up the road an hour or two to the local track, a 24' box is right on the edge of the capacity for an F150 or whatever 1/2 ton you like. Assume 1500# of additional stuff besides the car and that trailer will be close to 10k#.
You'll want a 3/4 ton diesel. I have the exact setup you are wondering about. Ford F150 and 24' box with a 1400# sports racer. Trailer is 7000# without the golf cart. Cart is another 1000#. I don't bring the golf cart if towing more than 200 miles because the F150 has to work a bit too hard for my liking. If emergency braking or incident avoidance is required, it's reasonable. Ford and others love to brag that their 1/2 tons will pull over 11k, but I wouldn't do it. You certainly can, and it will do it, but it's not comfortable. In fact, it's pretty sketchy. The box is the issue. Lot's of drag, big surface areas for wind.
Most reputable aluminum 24' trailers are in the 3500 lbs neighborhood base without cabinets. That 7000lbs trailer PierreP3 is talking about with a 1400lbs sports racer must be steel, full of cabinets and such. ATC and Intech seem to hold their value pretty well. It might hard to find one on short notice unless you are willing to compromise on options.
Towing a big enclosed is no joke - you need to really think about this and prepare. I'm assuming you already have the 1/2 pickup and thus 3/4 isn't an option. Therefore in my opinion you should be looking for the lightest weight and lowest profile trailer that will work for your car and you should also invest in a proper heavy duty hitch, weight distribution and sway controller.
