Tire Pressure Monitoring System/ Trailers
After a near disaster with trailer tire failure (See horror story "Trailer Tire Caper Rev3.docx), I vowed to do two things:
EEZ-RV recommends this install video found on their web site: www.eezrvproducts.com I watched it and found it helpful....but there were questions I had....I called the help line 928-317-8888, immediately spoke to a Tech (In Ontario, CA), he had time for me and answered my questions. I was up and running in a matter of minutes.
You won't drive a car without TPMS, so why would you pull a trailer without TPMS?
- Replace the Westlake tires with Goodyear Enduro (Made in the USA) trailer tires, done! Sold all 5 of these tires for $200 delivered.
- Buy and install a trailer Tire Pressure Monitoring System, done!
Trucker
Good call on switching to Good Year Endurance! If you ever run long distance, you should consider 2 spares wheel/tires.
We run a lot of tractor/trailers and typically on duallies when one goes flat and the driver does not catch it fast enough it takes out there one as well due to rubbing, excessive pressure/temp on the good tire, shrapnels, etc.
I remember reading about your Tundra tow vehicle. It sounds like it did well? Since from the sound of it trailer did not steer your tow vehicle?
TPMS: Don't Leave Home Without It.
We run a lot of tractor/trailers and typically on duallies when one goes flat and the driver does not catch it fast enough it takes out there one as well due to rubbing, excessive pressure/temp on the good tire, shrapnels, etc. ( I have my second spare tire mount on order, two spares is the only way to fly!)
The Tundra has worked out very well. Enough power for the hills I encounter runs cool while towing irrespective of ambient temp, , but just like the previous Tundra, mileage sucks....about 9 mpg towing. But gas is cheaper these days. It will run on 87 Octane but I don't have the heart..I run 89 Octane, and save the 91 Octane for the racecar. I can live with the mileage. The adaptive cruise control is awesome. It has a really nice trailer towing package as well, and a trailer towing mode, changes shift points, etc....
I wrote a little article relating the near disaster I avoided....you may find some irony and humor in there. Trailer Tire Caper (Attached below)
I always carry 2 spares and if I have to use one I look to have the bad tire replaced as soon as I can. I run the GY on the trailer but the spares are generic and removed as soon as I get the bad GY replaced. A shredded tire is bad but a catastrophic blow out will usually destroy the removable fender if you have those.
Peter
Peter
Manda Racing (06-14-2020)
Trucker
^OP, it sounds like the Tundra did well and you stopped just in time.
First trip with TPM on trailer
I felt much more confident pulling the trailer knowing that I have a handle on. tire pressures and temperatures. I am adding a second spare before my next trip to Laguna Seca...that blessed track is a mere 2 hours away. Here are a few pics from my last trip there.
Really enjoying the peace of mind from the TPMS on the trailer. Next step, add that second spare just in case.
Thanks for posting again on your own thread - and reminding us all of how much you're enjoying the "piece of mind" you're getting from your tire pressure monitoring system. Tell us more about your next step!
A little sarcasm here?
I didn't feel reluctant to post to my own thread based on the disaster that can occur with tire failure on a trailer.
My next step you ask? I needed a nudge to stop wasting my time posting. Thanks for that!
Assuming this is a snarky post, don't you have anything better to do? Piece of mind,,,yes indeed, a little piece of my mind is at peace, knowing that I have done everything possible to protect my that $100,000 I am towing behind my truck.
