Matrix headlights in USA now--or not?
So I saw that matrix headlights were now on the configurator and apparently available in the USA. This coincides with the news reports that such headlights are now allowed.
Then I saw this post (#76) on the Taycan forum. I can't find anything from Porsche saying that the headlights are in the car but not activated in matrix mode (or whatever it would be called) to verify this guy's post.
Anyone here know anything?
As far as I know they've always been available in the US configurator.
The matrix functionality still isn't allowed at this point, the bill only set a date for the study to be completed.
Even if they are approved, Porsche has no plans to enable this functionality, presumably because future US regulations haven't been designed for.
You are buying a slightly noticeable increased output, and optionally black or blue accents.
Aviator98ah (12-10-2023)
In the Configurator, if you click the "i" link next to PDLS+, at the bottom (you must scroll down), it says this:
Well, if you want to get technical the matrix LEDs do actually turn off and on--that is to replicate one beam as if they're on a swivel (left/right or up/down)--PDLS. It's actually kind of hard to notice since the dynamic lighting when cornering depends on speed and drive mode. You can kind of notice it when you're turning inside a neighborhood and can see your beam on garage doors.
The "+" in PDLS in the U.S is only automatic on/off high beam. LAME.
https://newsroom.porsche.com/en/2022...ogy-30770.html
https://www.porsche.com/usa/models/c...#exterior~open
Note: Full LED-Matrix functionality (individual operation of 32,000 LEDs) is limited for the US market. Individual LEDs are programmed to operate as a single light source to perform the functions listed above.
Interesting.
https://www.motorauthority.com/news/...%20this%20rule.
Audi has had the full matrix lights hardware since at least 2020. The trick is that, as noted by others above, they aren't activated in the US. There was someone who was helping members unlock the feature in their cars.
I would expect Porsche's lights for the US to be exactly the same.
Someone on the Cayenne forum is reporting that functionality is being enabled by an independent company and videos have been posted of US Cayenne lights enabled and functioning. Maybe check that out? I have them on my Canadian Cayenne and they are impressive. Maybe they can be enabled for Taycan as well.
In May I reached out to someone who mentioned being able to enable this.
My Taycan has the Porsche Dynamic Light System Plus, I asked if retrofitting the Matrix lights and enabling them would be possible, here is the response;
Retrofits will also be able to be activated as long as you have camera on the windshields.
I would be very very careful in proceeding with swapping LED headlights for Matrix headlights - story follows:
now YMMV - but this is a factual story for a North American Cayenne eHybrid Platinum delivered in spring of 2023 - retrofit was _NOT_ plausible even with factory porsche germany support at the local dealership.
proceed with caution - if you purchase parts I'd make sure you can obtain a refund if you can't use them.
- good friend ordered 2023 Cayenne eHybrid Platinum
- really really really wanted matrix headlights
- but supply chain issues - no matrix for his order with out major delay
- decided to proceed with order - no matrix
- porsche really really delay'd order - but car was delivered with LED non-matrix headlights
- he was upset
- porsche asked what they could do to make him happy
- he suggested factory support for matrix retrofit by his local dealer shop
- porsche agreed- sent all parts to dealer service and told them PCNA and Germany would support matrix retrofit
- dealer received all parts and instructions from porsche germany for the retrofit
- dealer worked the problem for 2-3 weeks - was unable to properly retrofit matrix headlights due to deep internal wireharness issues beyond the scope of reasonable retrofit
- porsche germany was surprised by this but after a few days delay confirmed necessary harness support for matrix is "baked in" to the vehicle very very early in assembly process - for Cayenne it is simply not practical to retrofit matrix due to differences it the 1st/main/major/primary harness package installed - you basically have to tear the car down to it's original just exiting paintshop state to replace this main harness
- now anything is possible with sufficient time/money - but tearing down a Cayenne to it's state when it exits the paint shop is _NOT_ a practical reality
- porsche germany was also unable to determine if there were other assembly differences that would be "discovered" in a retro fit process
- after long delay - porsche germany and local dealer determined matrix retrofit was not feasible due to "unfixable" wireharness problems with the main/bulk harness
- plan was called off due to cost/practicality issues even with factory engineering support
- you can tell if a Macan/Panamera is North American or ROW (Rest of World) even before it enters the paintshop - bare metal body stage of manufacturing
- how?
- it has the hole cut out in the roof panel for the XM sat. antenna which is North America only - and leads to a very very very different "roofing harness" that changes nearly _EVERYTHING_ for that car down the line
The following 3 users liked this post by daveo4porsche:
