Black Spec Boxster Build
#78
I'm getting towards the end of round 1 wiring cleanup. The alarm unit is ready to relocate, and I only had to extend two wires - a ground and an orange wire. Regarding the stock fuse panel and relay panel (greatly downsized), should I keep them in the factory location near the drivers left? I see people moving these under the dash, why?
#79
Down to 8 wires. Shrink wrapped, in case I need to reconnect anything. I found this nice summary from another racer. I validated for myself in the wiring diagram.
I = blue
II = black
II/1, 2.5, Br. , Earth at GP7 (the big brown wire that bolts beside the box)
I/2, 0.35, Or/Bk, Diagnosis (the OBD plug)
I/3, 0.35, Bk/Rd, Signal transformer box (nearsteering column)
I/4, 0.35, Bk. , Signal transformer box
I/12, 0.35, Bk/Ye, Signal transformer box
I/16, 0.35, Or. , Fuse E1 (fuse box)
I/23, 0.50, Or/Wt, ECU term 88 "w" lead - diagnosis
I/36, 0.50, Bk/Br, Fuse B6 (fuse box)
After shrink wrapping, I made electrical tape bundles.
I = blue
II = black
#82
Definitely move the fuse box and relays. The less around your feet the better I say
Here is what my car looked like right before I finished cleaning up the wiring. You can see there is much more room around the feet.
#85
Matt. Where do your wires run towards the back of the car now? I don't see anything down the left door. Also, I see you've got the original dash crossbar plus cage bar. I've heard of people removing the stock bar. Any thoughts there?
#86
Cage design to me is best left to cage designers, like Jay from JPC. The cage in my car was built by a cage builder who typically builds top fuel drag cars. As result it's both overbuilt and heavy. But my car is stiff and has easily survived a 4G impact with just sheet metal damage (drivers side). Personally, more bars are better!
#87
Correct me if I am wrong here....But all Boxsters have a pill in the key for the alarm control module ....some did not have trunk releases but all had a pill and removing it requires the dme to be modified so it does not need a transponder which is "ILLEGAL"
The Texas boys had a couple of cars this way and were disqualified for illegal modifications to the DME.....
#88
#90
So I got a few PM's on the ignition switch asking about how it's done, so rather than answer the same question multiple times, I will just answer it here.
There is no magic. As Provost pointed out above, removing the mobilizer requires an illegal change to the DME. However, the ignition switch is a point of failure. So I removed the pill from the key, disassembled the lock assembly to separate the mechanical barrel from the electronics. I taped the pill from the key to the sensor ring and then wired a start switch to where the original ignition switch was wired to. This removes the failure point, but keeps the immobilizer.
