Spec Boxsters For info sharing on this exciting new class
Calling all SpecBoxers...
Old 06-13-2012, 09:30 PM
  #301
Streak
Perfect Angel
Streak's Avatar
You are killing me with this stuff. Everytime you have something good and cheap I am broke!!!!!
Old 06-14-2012, 11:22 AM
  #302
TIM COSTA
TIM COSTA's Avatar
Hey Hunt,
Give me a call, maybe we can set up a payment plan!!
Old 06-14-2012, 03:40 PM
  #303
Werkstatt
Former Vendor
Werkstatt's Avatar
Tim,
I thought Paul had commited to buy them, give me a call.
Old 06-14-2012, 05:09 PM
  #304
Streak
Perfect Angel
Streak's Avatar
Originally Posted by TIM COSTA
Hey Hunt,
You coming to Hyperfest? Or VIR?
Old 06-14-2012, 08:34 PM
  #305
TIM COSTA
TIM COSTA's Avatar
I may be at Hyperfest. Do I need to bring the motors with me??
Old 06-14-2012, 09:30 PM
  #306
Streak
Perfect Angel
Streak's Avatar
Ha! No. You aren't that far away from me.
Old 06-20-2012, 08:30 PM
  #307
jdistefa
jdistefa's Avatar
Anyone interested??? I have two 2.5l Boxster motors that I need to get out of my garage. One is a very low mileage, <13K, and the other has just been refreshed. Both are long blocks and will need all intake and some other small parts tranfered over. I'd like to get $3000 each or $5500 for the pair.
Thanks,
Tim
Signed up for the refreshed long block
Old 06-20-2012, 08:33 PM
  #308
jdistefa
jdistefa's Avatar
Mosport... anyone? I have a funny feeling I'm going to be alone sorting through SP2+3 cars.
Old 06-20-2012, 09:47 PM
  #309
TIM COSTA
TIM COSTA's Avatar
Thanks Matt. Good luck at Mosport!!
PS both motors are sold.
Old 06-25-2012, 01:45 AM
  #310
J richard
J richard's Avatar
During my last few races the trans has gotten progressively stiffer as it heats up, to the point where it gets difficult to downshift. Near the end of the session I had to double clutch. Not abusing the box and when it cools down shifts normally. So I'm thinking it's time for the trans cooler. Question is is this symptomatic of overheating or is there another issue...
Old 06-25-2012, 01:33 PM
  #311
friscocayman
friscocayman's Avatar
That's the classic symptom experienced by those of us TX SPBs. Trans cooler has been successful in keeping shifts smooth.
Old 06-27-2012, 11:25 AM
  #312
J richard
J richard's Avatar
^^^thanks for the confirmation, thought that was it but surprised at how sensitive they are, (guess it's still a chick car underneath...) Time for the cooler...
The 944spec box has a similar problem although not quite as bad, using redline high impact gear oil solved it for a few guys, anyone running it in a spec boxster?
Old 06-27-2012, 02:33 PM
  #313
jittsl
jittsl's Avatar
I recently acquired the bits (mostly from eBay) and installed a transmission cooler on my SpecBox. Cost me about $400 all up and works perfectly. It was Texas temperatures at VIR last weekend and (when I remembered to turn it on) the box worked great - even after an hour and a half. If you need any pointers or help, drop me a line.
P.S. as an added bonus, by disconnecting one side or the other of the pump (which in my case is mounted in the trunk) you can use the system to drain and then refill the tranny fluid in about 10 minutes total. Much better than getting under the car and pouring oil on your head.
Old 06-27-2012, 03:23 PM
  #314
longhorn911
longhorn911's Avatar
Plus Laurie's cooler makes his car go really fast - congrats on setting the new lap record for SPB at VIR Laurie!
Old 06-27-2012, 03:41 PM
  #315
Streak
Perfect Angel
Streak's Avatar
Laurie, you have a very nicely prepared car. Post some pics of your cooler when you get a chance. I need to build my own and figure out why my engine temps were so high. I have never had engine temp issues.
Quick Reply: Calling all SpecBoxers...
