991.1 gt3rs side skirts on narrow body
Old 02-07-2020, 11:38 AM
polobai
polobai's Avatar
Received 1,125 Likes on 670 Posts
Default 991.1 gt3rs side skirts on narrow body
Good morning guys, a few people have been asking for a write up on how I was able to do this on my car (991.2 Carerra t). A word of caution-you will have to modify the skirts and wont be able to return them as you will have to cut them extensively. You will also need to drill two small holes into the car on each side (will explain below). What you will need:
Sideskirts (got mine from getporscheparts.com):
991504595901E0
991504596901E0
6x 3/16 fender washers
6x 3/4inch tek screws
2x #8x3/4 sheet metal screws
2x #4x1/2 sheet metal screws
Very sharp blade
Drill with various bits
torx drivers
The following 3 users liked this post by polobai:
awfilms (04-16-2020), browncf (05-01-2021), jesm (02-29-2020)
Old 02-07-2020, 11:46 AM
polobai
polobai's Avatar
Basically you would have to cut all the tabs off the rs side skirts and create new mounting points to mate to the body.
Cut all the tabs and protrusions off with a sharp blade-be careful!!!
Old 02-07-2020, 11:48 AM
polobai
polobai's Avatar
Before
Cut these off and also remove the white clips on the bottom (just twist off)
You will pull these clips off before cutting.
Old 02-07-2020, 11:52 AM
polobai
polobai's Avatar
You will also need to remove anything that will get in the way of the skirt sitting flush against the body
Cut this off from the front
Should look like this when done
Trim this (keep the speed nut-will need it later)
Will need to remove this from the back as it interferes with the rear mud guard
Like this
Old 02-07-2020, 11:57 AM
polobai
polobai's Avatar
You will also need to trim about 3/4 of an inch from the rear of the skirt on the bottom as it interferes with the lower sill panel on the chassis
Trim inside the tape line
Closer pic-you May have to trim more or less depending on your fitment (I noticed I had to trim more on the passenger side than the drivers side)
9ONCE (07-27-2020)
Old 02-07-2020, 12:04 PM
polobai
polobai's Avatar
Now that everything is trimmed, time to work on mounting. I secured mine with 4 screws on the bottom, one in the rear and one in the front. Holds steady and strong.
Remove this fastener from the front of the car
Remove this speed nut from the front of the skirt and keep it handy
Like so
Clip you will need for next step
Old 02-07-2020, 12:08 PM
polobai
polobai's Avatar
Here is where you have to drill a hole in the factory mudflap out back
Remove the fasteners on the bottom of the factory mudflap so you can tilt it down
Take the speed Nut and install as far back as you can on the mudflap
Mark where the screw will go through and drill a hole (I used a 3/16 bit I believe). From there reinstall the speed nut and mud flap
Old 02-07-2020, 12:13 PM
polobai
polobai's Avatar
This will serve as the rear mount for the skirt. You will now need to drill a corresponding hole in the back of the skirt and mount using one of the two methods below
Using #8 x3/4 inch sheet metal screw counter sunk and then covered with a piece of Matt black vinyl (use a hole punch to get a perfectly round circle)
Or you can use a #8 tek screw and cover. Both are not too noticeable once covered in Matt black vinyl
Old 02-07-2020, 12:21 PM
polobai
polobai's Avatar
Time to make the rest of the mounts. Utilizing the existing hole in the front of the skirt (where you removed the speed nut) mount to the body using the existing body mount and faster here
Mount using the oem location here
You will drill the tek screws into these three other spots on the bottom of the skirts on each side
Like so
Old 02-07-2020, 12:24 PM
polobai
polobai's Avatar
Now it’s time to take care of the front. Here is where you have to drill a hole into the body-super tiny.
Pull the front into position and drill a corresponding hole for the #4 screw to hold
Countersunk and screw installed
End result
Covered screw head in Matt black vinyl
Old 02-07-2020, 12:32 PM
polobai
polobai's Avatar
If all goes well, you should end up with something like this
Front fitment
Rear fitment
jesm (02-29-2020), tourenwagen (07-27-2022), Wilder (11-27-2022)
Old 02-07-2020, 12:39 PM
LargePuppy
LargePuppy's Avatar
You sir, are magnificent. I look forward to many many more of your guides
Also, is your front lip different?
Old 02-07-2020, 12:46 PM
polobai
polobai's Avatar
Thanks, glad it helps! Yes, my lip is a bit different-please see this thread on it:
https://rennlist.com/forums/991/1157...ubber-lip.html
Old 02-07-2020, 12:53 PM
polobai
polobai's Avatar
Also for those interested I added front mudflaps as well. I mounted these using two extra speed nuts I removed from the skirts and trimmed the profile of the mudflap the match the rear oem flaps
Amazon Amazon
Mudflaps from Amazon (after trimming on one side)
Using the oem rear mudflap as a template
Put a slit in the fender liner and install the speed nut
Drill the other hole directly into the fender liner to hold it in position. Drivers side installed
Passenger side installed.
AdamSanta85 (02-07-2020)
Old 02-07-2020, 12:54 PM
ShaunP
ShaunP's Avatar
Very nice!
Quick Reply: 991.1 gt3rs side skirts on narrow body
