964 Forum 1989-1994
Porsche 964 - 200kg challenge
Old 12-11-2019, 04:22 PM
911Jetta
911Jetta's Avatar
Default Porsche 964 - 200kg challenge
This will be fun to watch.
JP-"S" (01-11-2022)
Old 12-11-2019, 04:25 PM
Spyerx
Spyerx's Avatar
Received 1,789 Likes on 1,089 Posts
from a stock car, totally doable, even keeping heat and AC and adding safety.
911Jetta (12-11-2019)
Old 12-11-2019, 04:55 PM
SR20Fastback
SR20Fastback's Avatar
https://youtu.be/DDJXI0Q8eg4
I'd settle for that in ground scissor lift.
Old 12-11-2019, 11:21 PM
RyanH.
RyanH.'s Avatar
I wouldn't say it's easily doable. Here's my spreadsheet. If the corner it came from is listed, that means it has been done. I haven't been super diligent about weighing things so not everything is 100% accurate. If you see lbs listed in a nice round full increment, it's probably a guess otherwise it's been weighed in grams. I'm now at the point where things begin to get expensive (sunroof delete etc...)
The following 3 users liked this post by RyanH.:
911Jetta (12-12-2019), HiWind (11-02-2020), I am the Walrus (02-09-2020)
Old 12-12-2019, 03:59 PM
Earlydays
Earlydays's Avatar
Don't over look the additional reduction by going to "Weight Watchers", easily worth 20lbs......
The following 2 users liked this post by Earlydays:
Hella-Buggin' (12-13-2022), JP-"S" (12-12-2021)
Old 12-12-2019, 04:12 PM
RyanH.
RyanH.'s Avatar
Unless you're 155-160lbs like me...but it's worth a try, should help with cycling!
Old 12-12-2019, 05:27 PM
Jonte
Jonte's Avatar
Thanks for the feedback!!! It’s really cool to see someone else picked up on my little endeavor.
For what it’s worth I have a huge pile of more stuff on the garage floor now and should post episode 166 in about 2 weeks.
The following 5 users liked this post by Jonte:
911Jetta (12-12-2019), BLACK3.2 (12-13-2019), Garydose (01-06-2020), HS911 (01-08-2020), kos11-12 (12-19-2019)
Old 12-12-2019, 05:33 PM
911Jetta
911Jetta's Avatar
Looking forward to the next episode!
Old 12-12-2019, 09:22 PM
Spyerx
Spyerx's Avatar
When I say easily that is subjective. I mean, keeping it a street car and not going so nuts you have an uncomfortable POS. About 400lbs is easily doable, its just $ :-)
My car stock weighed about same as yours and is lighter now, with AC and a welded in roll bar. A few things you are missing are various chassis components: lighter brakes, lighter rotors, I removed PS but added an electric pump, lower dash, shocks the stock ones are heavy!), springs (small race springs vs. the stock beasts), bumper components. Stock heat exchangers are BOATS, go with a light header, anyway, it all adds up, wheels (cup1 are heavy), tires (some are much heavier). RS uprights are a lot lighter, various suspension components vs. stock...
It ALL adds up.
Tell you what tho, you can feel it. That few 100 lbs makes a big difference.
Anyway, 2600-2700 is about the limit and keeping it reasonably streetable in my opinion
zmon (11-18-2020)
Old 12-13-2019, 10:08 AM
911Jetta
911Jetta's Avatar
Originally Posted by Spyerx
...Tell you what tho, you can feel it. That few 100 lbs makes a big difference...
This! Have other 964 owners driven your car? I'd love to see there reaction.
As a cyclist, it's all about hp/weight, so I'm naturally drawn to lightweight design. I have a bunch of road bikes, and the lightweight ones all feel amazing to ride, so lively. I may not climb any faster on the lighter bikes, but they feel better all the time.
So I want to experience that same feeling in lighted, focused 964... one day.
Old 12-13-2019, 04:24 PM
GoatFarmer
GoatFarmer's Avatar
Remove the glue with gasoline and a rag. That is how I did it with my E36 M3.
Now that I'm older I'm a believer in the easy button. Buy a nice street car and a nice race car. Job done.
The following 2 users liked this post by GoatFarmer:
Henrik964 (06-22-2022), luv2race (05-14-2020)
Old 12-14-2019, 03:15 AM
Spyerx
Spyerx's Avatar
Several have driven it. All enjoyed thoroughly. It’s an absolute ripper in the canyons.
911Jetta (12-14-2019)
Old 12-14-2019, 05:05 AM
Jonte
Jonte's Avatar
in my case the solution is going to be media blasting. I won’t be able to really sort it out completely without this and to make it look good.
Old 12-14-2019, 08:34 AM
2swoosh
2swoosh's Avatar
no cage if you won't race it and you might achieve 2700 lbs or less. lightweight is free hp
Old 12-14-2019, 06:29 PM
Jonte
Jonte's Avatar
Still in the middle of pulling cables out...
islandsnow (08-02-2021)
Quick Reply: Porsche 964 - 200kg challenge
