911 Forum 1964-1989
stuck clutch pedal 1980 911 SC
Old 08-17-2017, 06:50 AM
  #166
rscone11
rscone11's Avatar
I have the engine on the cart. Is it ok to have the weight spread onto the heat exchangers? My cart is 30" wide.
Old 08-17-2017, 06:54 AM
  #167
proporsche
proporsche's Avatar
yes don`t worry they are strong......just balance it and put a jack under the trany...
Old 08-17-2017, 10:09 AM
  #168
theiceman
Team Owner
theiceman's Avatar
Received 1,111 Likes on 794 Posts
Sorry randy I must have removed the sway bar and forgotten. Looking where it is on your pic it is obvious I removed it. I obviously just forgot.
If you have an extra jack you can just take the weight of the transmission if you are concerned about the shift rod as you undo the transmission bolts as you lift the car. . It should have wheels though as you are going to pull the engine back as you lift the car.
Old 08-17-2017, 03:37 PM
  #169
r911
Anti-Cupholder League
r911's Avatar
watch for any wires or hoses you missed while slowly pulling the motor back and down
have a helper with cell phone ready
the motor sits real well on the heat exchangers
won't hurt to have a list of those wires & hoses for the re-install
Old 08-18-2017, 08:21 AM
  #170
rscone11
rscone11's Avatar
thanks r 911. I should have some photos later today.
Old 08-18-2017, 08:42 AM
  #171
theiceman
Team Owner
theiceman's Avatar
is it out Randy ?
Old 08-18-2017, 08:43 AM
  #172
theiceman
Team Owner
theiceman's Avatar
it may be worth you picking up Wayne Dempsey's engine rebuilding book. It has excellent tips on taking engine in and out and also just a great book to have.
Old 08-18-2017, 11:56 AM
  #173
rscone11
rscone11's Avatar
hey guys it is not out yet, just about to pull it back but found a black wire on the right side of trans and tunnel not disconnected. Photos provided What is it for and where do I disconnect?
Old 08-18-2017, 12:01 PM
  #174
rscone11
rscone11's Avatar
photos attached.
Old 08-18-2017, 12:06 PM
  #175
theiceman
Team Owner
theiceman's Avatar
when I did mine I just undid that small 10mm and the piece of metal holding it in, then it falls out. if I remember correctly I took it right out , I think its the speedometer pickup. see the small hole to the right in the pic ? there should be a bellows over it, if you pull that off its the black wire you see with the connections to the speedo you disconnected, its these same wire so if you want you can leave it in place on the transmission and just pull the bellows off and the wire out .
Old 08-18-2017, 12:50 PM
  #176
rscone11
rscone11's Avatar
Its out.
Old 08-18-2017, 01:04 PM
  #177
theiceman
Team Owner
theiceman's Avatar
woo hoo .. outstanding work Randy ...
now you get to grab a cold one , sit on a chair and stare it for a bit ..
plus don't forget the standing in the engine bay pic ..
Old 08-18-2017, 01:06 PM
  #178
theiceman
Team Owner
theiceman's Avatar
now its only 4 bolts or so into the transmission ,,, did you peek through the inspection hole ?
looks pretty good too and dry .. just dirty more than anything ..Depending on what you want to do while its out you could be back in and running by the end of the weekend.
Old 08-18-2017, 01:11 PM
  #179
rscone11
rscone11's Avatar
Thanks! I'll clean it up for sure, doesn't drip oil really, just a few small weeps. The guy I bought it from just sent me 2 more receipts from 2006. Total of $3000 in work. All brakes, distributor, tune up, and odds and ends. Just got them today.
As I look it over it appears there are 3 bolts plus 2 hex bolts for the starter? Is that correct. DO I remove the starter?
Grabbing a cold one now.!! l
Old 08-18-2017, 01:23 PM
  #180
theiceman
Team Owner
theiceman's Avatar
yes randy pop the starter off I think its an M10 hex then support the transmission and undo the other bolts . they may be different lengths so take notice just in case.. remember as you pull the transmission back ( huffing and puffing ) the cross shaft will turn and the clutch lever underneath with it as it unhooks from the release bearing, make sure the levers aren't binding underneath the transmission on your dolly and can turn or it will fight you.
I remember having to take some of the exhaust off but it may be my imagination.
also post bigger pics so we can get a good look .
Quick Reply: stuck clutch pedal 1980 911 SC
