what did you do with your 968 today.....
#151
Registered User
Originally Posted by Chuck Z
Yes. There are two shock options in PET, stock or M030. I used the stock springs b/c I didn't want to stiffin it up too much. Didn't use rear springs b/c I was told rear end would be raised like a 4-wheeler (and too stiff). I set both front and rear adjustment settings to the softest setting. Right now, the fronts are at their lowest point and I'm sure I'll have to raise it up b/f I get an alignment done.
#152
Registered User
Sorry, it's express service to get parts in Germany here quickly instead of waiting for stock order that could take a month or longer. Cost like 20% of part price if memory serves. There might be a max cost, don't remember.
#158
Registered User
Thanks Jerry. Still have quite a bit to clean on the backside of what you see here. Found some stuff that make quick work of removing the cosmoline. Still a messy process tho...
#160
Pulled the injectors out of Lagoon to send off to Witchhunter Injector service.
I will post the before and after flow charts from these guys. Cost is $22 per injector and you get a complete before and after flow analysis. With shipping and all should be about $100 and the reports are great.
#165
Registered User
![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
