996 Forum 1999-2005
CEL came back...Finally got around to getting a Durametric
Old 05-25-2017, 06:44 PM
  #151
Ahsai
Ahsai's Avatar
A sliding hammer puller with 3 built-in heel bars...nice. I think it also took me some effort to remove the IMSB flange on my '02 996. I used those mini heel bars as well.
Old 05-25-2017, 11:29 PM
  #152
dporto
dporto's Avatar
Received 1,165 Likes on 795 Posts
A few tools and things came in today so I couldn't wait for my lady's foot prybars... For one I got my thermostat gasket (why it doesn't come with the water pump is beyond me) so I put that on... then I couldn't leave well enough alone so I started massing with the ims flange... that's when it hit me that I might be able to use the ims puller tool with my wheel bearing "bridge" to pull the flange... it worked
I'll get deeper into the explanation in the morning...
Old 05-26-2017, 08:39 AM
  #153
dporto
dporto's Avatar
As you can see in the photos above and below, I've got a dual row bearing. The problem for me is that I can't tell if it's a true "dual row"(I think it is) or a single row pro - does anyone have the dimensions of the dual row bearing? It's a little perplexing to me because my engine is a M96-04 (manufactured in 2000) so it's from the period when they were using both types of bearings. They bearing seems to be in great shape - the cages are totally intact as are the ***** that I can see (I haven't removed the rear seal yet). The oil in the front of the bearing was super clean, and there was no oil to speak of in the shaft. Bearing depth 20.15mm
You can see a little galling on the bottom of the bore
You can see the edge of the flange is bent(upper edge in photo- is actually the lower edge of the flange)
So, it's pretty obvious that whoever did the last retrofit jammed the flange in crooked and caused that galling and the bent edge of the flange. No wonder it was so difficult to get it out The question now is how to deal with the bore. I'm thinking I'm just going to try to burnish the little ridge that's there and then just use a little sealant when I install the flange. Sound feasible? Any other ideas?
Old 05-26-2017, 09:39 PM
  #154
Porschetech3
Porschetech3's Avatar
Received 4,586 Likes on 2,078 Posts
The factory dual row is 23.8mm thick (proprietary to Porsche) , the single row is 14mm thick. The available dual row aftermarket bearings as yours 20.15 and require a spiral lock and also a spacer ( or custom thicker flange) to make up the difference.
Old 05-26-2017, 09:53 PM
  #155
Porschetech3
Yours is the aftermarket LN dual row with the custom thicker flange.
Old 05-26-2017, 11:59 PM
  #156
dporto
dporto's Avatar
^Yes^ thanks for the reply ! LN Engineering has acknowledged that it is their "classic dual row retrofit IMS bearing"... I've ordered the dual row Solution to replace it...
Old 06-02-2017, 08:26 AM
  #157
dporto
dporto's Avatar
In the last week I got the IMS Solution and the two tool sets (IMS Pro and Supplemental) necessary to do the install. Last night I put a couple hours in and did the install. The actual installation of the IMS end plug and the bearing itself was a piece of cake - The flange, not so much. The fit of the flange to the bore was fine, but the positioning of the oil feed was much closer to the center-line of the case halves than in the instructions (sorry no photo's yet - it was late last night). The Dremel tool was my friend, and after many adjustments with the cutoff wheel I was able to get the oil line to clear the crank case. more photo's to come later.
Notch in case started- I wound up having to go much lower or further toward the center-line where the case splits.
Ims plug installed
Old 06-02-2017, 10:39 AM
  #158
dporto
dporto's Avatar
And, no... I haven't gotten to the cam chain tensioner pads yet, as I'm STILL waiting on a bunch of parts I ordered on 5/16, from Autoatlanta...
Old 06-03-2017, 09:32 AM
  #159
dporto
dporto's Avatar
A few photos of the finished "Solution" and then on to the reason for you his whole exercise!
Old 06-03-2017, 09:48 AM
  #160
dporto
dporto's Avatar
Ok, so I finally got to the cam cover after finishing the IMS Solution last night. As you can see in the photo, whoever had this cover off last, used a crazy amount of sealant...Now I know that the black stuff in my oil pick up tube wasn't chain pad material...
I think it's going to take me awhile to get this stuff cleaned up🙄
Old 06-06-2017, 08:29 AM
  #161
dporto
dporto's Avatar
I got the vari-cam pads last night. All of 15 minutes to actually change them out...bank one is now done. The pads themselves were barely worn. I'm thinking maybe the actuator is bad? How can I check it?
*** for some reason my photos won't upload... I've tried twice now...😰
Old 06-06-2017, 08:55 AM
  #162
dporto
dporto's Avatar
I'll try this one more time Bank 1 Cams out on the bench
Actuator out. Top rail very little wear
Bottom rail very little wear
New rails installed
Actuator back in. The trick to installation is to let the sprockets hang off the edge of the bench
Back in the motor
All back in with all bolts torqued.
Old 06-06-2017, 09:45 AM
  #163
wildbilly32
wildbilly32's Avatar
Impressed!
Old 06-06-2017, 04:41 PM
  #164
dporto
dporto's Avatar
Originally Posted by wildbilly32
Impressed!
Meh... when the engine is back in the car, running and without codes, I'll take the props!😄
Old 06-06-2017, 06:55 PM
  #165
Paul Waterloo
Paul Waterloo's Avatar
Interesting that you did not find the pads worn. So what are you going to do? Put everything back together or troubleshoot the actuators while out of the car?
Quick Reply: CEL came back...Finally got around to getting a Durametric
