Deal of the century???
#31
Looking at that parts list, they are replacing the variocam timing actuators (PN# 99610530371). Not the variocam lift actuators (these would be PN# 99610530172). The variocam timing actuators are on top of the cylinder heads, the lift actuators are in the spark plug valley.
The fault specifically calls out valve lift...oh boy. doesn't seem like this shop knows what is going on. If you get it, good thing you have a 2nd 996TT to pull parts from to replace the issues this one may have
I'm not saying not to get it, just hope you know how to/like to work on these cars.
Agree with Chris!!! Strange evaluation going in different directions....Replacing both camshaft actuators for a valve lift problem ???? Valve lift can be troubleshoot by looking at electric signal to the actuators and can be test easily with a PST2 or PIWIS or Durametric, all this before taking the engine out!!!!
#32
This may clear some things up or make things more confusing![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
. The owner sent me this text last Wednesday. I didn't think much of it but might or might not explain.
This is a direct copy and past of the text message::
Update on car: next Tuesday delivery (I pick up tues pm) confirming I had the actuators replaced as well more as a preventive maintenance for the future. These things go eventually. So while the engine was out, I took care of it. Along with the major service done last year, this thing should be right and tight. More to follow as I hear new info
#34
Originally Posted by jpflip
The posting has been deleted by its author. UWRASTA did you bought it?
Update: insurance inspector approved the lifters. Joe also told me the actuators could use replacing. Not a "need to have" but he said I should take care of it since the engine is out. I agreed to replace the two actuators as well. This way, the issue won't bite you down the road. They are looking to finish everything by Friday. so...in excited to get the car back. I'm honestly craving to drive it
#35
Yes I don't have much faith in this shop either. the dude had an extended warranty and could have taken it anywhere but he's been taking it to this shop cause it's close. so in theory if they replaced the wrong parts wouldn't the car just throw codes once it's was put back together??? Or would it run beautifully, pass a thorough ppi from cantrell, then once I purchased it start falling apart.
As far as identifying the problem, it will probably drive fine at low-mid rpm, and low-mid throttle position, and it may take a few WOT pulls and variocam change over points for it to trigger the faults. When it realizes the variocam actuator isn't creating the correct effects based on data the computer gets back from the sensors, it triggers the misfire faults and will go into limp mode until you turn the car off and back on again and it resets, when it will drive fine again.
It isn't going to fall apart if this is the issue.. It's a couple hundred bucks for a lift actuator and is no more difficult than changing spark plugs to replace it.
#36
My actuators would get signal with activations on durametric, they would change idle or could hear them click when car is off. Had to watch live data and compare to another functioning car to realize something was off.
#37
uwrasta- I live in Bellevue not far from Cantrell/work in Redmond, if you want a 2nd set of unbiased eyes on it I'd be happy to help you look over the car before or after PPI also.
#38
Im not going to be surprised if that misfire is still there after all of this work.
Those are the same codes and symptoms from variocam solenoid failure. Hope they tried that before tearing that deep into it. When I had that problem, I saw a few threads with things like this, even a couple of people having full engine rebuilds.... Simple fix....
#39
![order](https://rennlist.com/forums/graemlins/order.gif)
Hopefully the shop will realize the bracket is cracked if that is the case. Maybe they knew it all along and the car is put together and the shop owner is enjoying it for a bit
uwrasta if you buy the car and it needs a new bracket I have a couple of spares that are in good shape, just took them off of my car and put fresh brackets on when I changed my actuators.
#40
#41
So the brackets can be cracked and it causes a miss fire and some have said a stumble. But the solenoid does not leak oil? Just wondering because I have unresolved hickup/stumble and was wondering if the bracket/actuator could be the cause. How do you you check these, remove the heat shield and try to look in there? I have used the durametric to actuate them and I get a repeatable speed change.
#42
Good thread on the subject here: http://www.6speedonline.com/forums/9...-brackets.html
also here: http://www.pelicanparts.com/techarti...eplacement.htm
#43
So if the shop is wrong and it's a $300 fix to make it right, why is anyone saying to run away from a $32k X50 6 speed with a clear title in otherwise good condition? Salvage title value on that car "as is" right now is easily $25k+.
#44
![](https://cimg8.ibsrv.net/gimg/rennlist.com-vbulletin/640x480/tappet_solenoid_sized_0187c9c7dfdf2c9cc67bb15912bd0c17470b96f2.jpg)
If the brackets are fine there is a way to bench test the solenoids. I have not a bench test but I think some others here have. Maybe someone will chime in with that procedure.
Are you getting any codes?
#45
I'm interested to hear the outcome on this one.
