Who has the coolest wheels/ride height on their 964?
#618
#619
Personal taste. I wouldn't do it on my car, but I can appreciate the look as much as any other non performance oriented wheel setup. That car looks really good j_m.
#620
Originally Posted by JJJMCD
The car looks nice, but those wheels are downright bizarre. Are the centers taken from a set of 14 inch BBS wheels and surrounded with 18 inch hoops? Why wouldn't you start with the correct size centers?
#622
well dayum! betcha can't eat just 1..., to coin a phrase, but, also a not so subtle hint, more pics please.....!! beautiful!
#623
Just my preference.
#627
Absolutely amazing!
I was wondering too, rear ones look like 964 turbo flares and the fronts like RSR's but then again they could be just Turbos because the front spoiler is so different from original 964 turbo.
#630
This 911 required extensive body work to arrive at its present shape. DP Motorsport Germany
welded all mirror and sill cover holes, adjusted the tail fin, the spare wheel tub and front panel.
The roof, doors and rear lid are still original steel parts. For all other parts spezial moulds
were fabricated to reproduce original RSR/ST shapes and the long hood.
The hood, fenders, wings and bumpers were drawn up in carbon/kevlar.
Headlights feature new Porsche European lenses and H4 lights.
Instead of mounting a ducktail the retractable rear spoiler got redesigned
to integrate the grill from the early 911 and support the desired ST-flyline.
The PPG 2-stage Sandbeige is similar to the factory color code 6807 from 1968 and was applied
over a white basecoat.. Trunk space sprayed in sandbeige, engine compartment, interior body
panels and underside sprayed black matt as it was in the good old days of the early 911.
All of the rubber gaskets and seals have been replaced, and all exterior trim is either chrom plated,
polished aluminium, or polished steel. Outside mirrors are genuine Talbot Berlin. Side-Decals are
light ivory and the original Porsche lettering in gold of the early 911S on the engine lid.
Original 15 forged Fuchs wheels measure 9 at the front and 11 wide at the rear and are fitted
with Pirelli P7 Corsa Classic. Michelin TB5 R is an option.
15 Fuchs was one MUST on our design-list for RSVT#5. The other design principles were:
Rounded shapes of ST/RSR, NO sill cover to hide any oil/AC- lines, NO ducktail!
All to create the Look of the late 60s of these cars in Racing.
The offset of the wheels is customized to compensate for the wider axles a 964 has
compared to an early 911, but also to allow using bigger breaks from the 964RS.
Interior modifications include early-style lollipop race seats, 4p willans safety belts,
contemporary rollbar, deep Momo steering wheel, dashboard, door panels, knee pads, ashtray,
armrests and sidewall covers, A and B pillars and hand break cover,
ALL wrapped in black leather, seat inserts and door panels perforated.
Black vinyl headliner and hair yarn boucle carpet also custom made by upholsterer.
Center console have been deleted and switches, cabling converted into dash.
GT2-shifter from the 993 is installed with an open switching backdrop
Chrome mirror original from the early 911.
Original 964 gauges redesigned and converted to match the style of the early 911.
Glove box, radio, HVAC controls and air nozzles have been redesigned and integrated in
a custom made aluminium trim. Switches for cig lighter and fog lights deleted.
Retrosound 2 radio installed with Becker Mexico style trim and *****,
paired with 4 high performance speaker in doors / rear shelf.
USB plug integrated in ashtray allows charging phone, bluetooth hands-free operation.
Odometer has been reset, but we have documentation of the previous 72k mileage .
Despite of having a recent fully overhauled 3.6 L engine when we acquired the car,
we opted to build a brand new 3.8 L engine from scratch.
Engine bay should look totally stock including additional heating and AC compressor.
Schaertl Racing rebuild the motor and the car now produces 340+ rear wheel horsepower
at 6,600 rpm as confirmed by the included dyno sheet.
Final wheight is said to be 2450 pounds.
The engine and chassis build includes the following:
Engine
New rod bearings and bolts
Connecting rods modified (Schaertl Racing)
New cylinders and pistons 3,8 L giving 11.8:1 compression (Mahle/Woessner)
Heads modified for high compression and valve job (Schaertl Racing)
New RSR valve springs and retainers
New 964 RSR steel studs
New gaskets throughout 964RS
New large oil pipes
New sliding rails
New valve covers
3.0 clubsport cams
Engine balanced and blueprinted (Schaertl Racing)
Flywheel and crankshaft balanced
Dual oil coolers, left and right front fenders
M&M stainless steel manifolds, exhaust and RSR style muffler, 2*100cell cats., heating
DME and engine tuning by Bruce Henni / Schaertl Racing
Ignition
New 964 twin-plug distributors and wires
Air/Fuel
75mm throttle in a central plenum aluminium / race version
large intake manifolds and injection valves 964RSR
HFM air flow meter
Large air filter box with plenum adapter and sport filter
Transmission
Build by Schaertl Racing based on original G50.03 restored
Limited slip differential from 993GT2 (40/65%)
Sachs power sport clutch and pressure plate
OEM 964RS lightweight flywheel
GT2 shifter with open switching backdrop and unibal bearings
New wheel bearings and sleeves, all parts replated, aluminium dry ice blasted
Brakes
New 4piston 964 calipers (rear)
New OEM brake discs 964 RS rear (299/24mm)
New aftermarket sport discs 964 front (288/32mm)
Stainless braided break lines
EBC sport pads
Castrol SRF race fluid
Suspension
KW V3 Clubsport Suspension with aluminium camber plates front and rear
OEM 964 Cup strut brace
24/26 sway bars
All suspension components dry ice blasted, powdercoated, painted or replated
Alignment, ride height and corner balance by Schaertl Racing / KW 7-post dynamic rig
