help on Jacks and Jack stand options
I am new to the Porsche DIY world and am looking to build up my tools. One thing I would like to be able to do is to do my oil changes and to change the engine mounts in the spring, as well as work on my wheels.
I was looking at jack stands and jacks today in Canadian tire and was a bit overwhelmed by the options.
What are the differences between the cheaper and crazy expensive ones? What should I be looking for? I figure for a '99 996 I would not really need anything more than a 2 - 2.5 tonne lift with a low profile rating.
Suggestions on brands for jacks and stands, options, capacity, etc...
What to stay away from...
Thank you
D
Thank you
D
The thing with the higher rated stand is the stance is larger and more stable.
Although I use the "notched' type, they have always made me feel uncomfortable.
The screw or pin type is nicer, but more expensive.
One fail can lead to terrible consequences.
here's a link, 2 ton, ~2 3/4" minimum height....most importantly a long snout... http://www.canadiantire.ca/en/pdp/mo...0226p.html#srp
Motomaster version is 9-0226-6, Michelin version is 9-1052-2 http://www.canadiantire.ca/en/pdp/mi...1052p.html#srp
While I primarily use hoist, also have used my Michelin one a bunch and has been strong...heavy solid steel, but tough...
These aren't cheap, but look mighty convenient: http://www.jackpointjackstands.com/Home_It_Works.html
Although for not too much more than those plus a good jack, you could get a QuickJack.
I've used a 2 ton CT jackstand for 20+ yrs. No issues. I have a 1.5 to 2 ton Jack I bought at the grand opening of the Weber st CT back in 1996..
Our vehicles aren't that heavy.
I've now got a 2 post lift, but will keep the Jack's and stands.
I use a Michelin floor jack that I bought from crappy tire on sale. The thing is yuge. Very stable and easy to move.
