Fun DIY: new pads, rotors and hardware is on!
Spent the afternoon after the GTG changing all 4 rotors and pads. First corner took me about an hour as I took it slow to familiarize myself with all the bits and pieces, the others went much faster. I think the last corner took 20 mins including adjusting the parking brake shoes! I did everything by the book and replaced all dampers, caliper bolts, spring kits, pins, etc... I know a lot of people don't go that far, but I can't understand why not. The pad springs were pretty beat and the piece that holds the pad sensor wire in place snapped on one of them. I would recommend that the few extra $$'s is money well spent.
Nothing was seized or difficult to get off on this "winter beater"!
Tomorrow I'll detail the wheel openings and put my summer wheels and tires back on.
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
Did the same thing in the fall - crazy how easy the brakes are to service on these cars isn't it ? I swap the pads for track days and I swear it takes longer to get the wheels on and off than to change the pads over ...
Great job. You should probably throw a few of the old parts into a ziplock and put it in your track kit, just in case someone loses theirs at the track.
Yes, the impact screwdriver is a must!
The exterior of the calipers gets clay barred and sealed. Going to spend a few hours getting everything nice and clean before I bolt the summer wheels back on.
Just FYI, I don't think u need to reinstall that screw back in there.... to make it even easier for next time.
It couldn't have been easier even after sitting there for 8 years. The impact screwdriver just makes sure you don't strip the heads. Quick squirt of PB Blaster and you're good to go.
Question: antiseize. Is there a preference between the silver and the copper antiseize?
I have a large 15yr old vintage (12oz?) bottle of the silver..... This thread specifically mentions copper. Just wondering.
re: screw.
Just a data point
I have broken that caliper screw with the exact same hammer driver before. I've had to drill it out on my Honda and Acuras before. I'd say about 66-80% success rate with that impact driver. I actually broke the phillips bit once.
re: screw.
Just a data point
