Turbo Honda K-Series swap into my Porsche
#33
The only other engine I really wonder about is the Cadillac CT-6 engine..
same as a LS on the rear and 2 cylinders shorter... Twin turbo..
Used they are about $8K Just gets me thinking,, a Caymen body would rock it well..
#37
I actually think this swap could be good option for all the aging 996 cars out there
As for me and this car, since its not a roller and the engine is perfectly good. I can technically just sell the 3.8 engine and could possibly get close to breaking even on this project
#38
Though, $8K for the used engine is a pretty steep starting point for the swap considering there is a significant cost for all the other parts for the swap
#40
Captain Obvious
Super User
Super User
I came to this conclusion after reading others using, other version of VW engines that bolt up to the Porsche gearbox. These VW engines have transmissions that bolt up to the TDIs so logically the TDI should bolt up to the Porsche transmission too. BUT please take this as a non first hand experience info.
#41
#43
That CT6 engine could be a good option as well - If it shares the same transmission bolt pattern as an LS you could utilize a lot of the already available LS to Porsche swap parts
The 2014 silverado 4.3 is 340HP stock and all Aluminum, another potential option for < $3000
#44
I had briefly considered a sort of similar engine - The Ford Ecoboost 3.5L V6. They are plentiful, fairly inexpensive, proven to make pretty decent power, with the benefit of lots of aftermarket support
Unfortunately, they dont have the best track record for reliability, but i suspect thats partly due to maintenance and long oil change intervals
Sloss (09-07-2019)
