Crash: Instructor braces himself with his feet on the dash.
#226
WRONGLY ACCUSED!
Received 4,156 Likes
One fact which I think has really been overlooked is that the driver says it was brake failure.
We are up to 15 pages because we think he is just covering his a$$?
It looks like brake failure to me. A bunch of people here think its brake failure. The driver said its brake failure. Perhaps its brake failure?
#227
My first responder said it is posted on Face Book as a brake failure. I don't see it that way. What I learned is not to put my feet up on air bag if in passenger seat to brace myself. That was where this all started.
#228
If this was a relatively green student it is possible that he locked his brakes initially giving rise to the squirrelly behavior and then just panicked after that. It happens.
#229
#230
However, the bad downshifts and quick releases of the clutch, might have started the ball rolling.......also, being in neutral didnt help (or clutch pressed in)
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
I understand what you are saying. But, the brakes looked pretty good to me going into the toe. The car didn't ride any turtles after that. If the brake pedal was really soft or something going into the toe, then it would have been nuts to take a pass before the heel.
Perhaps. But I believe he hammered the brakes and as the rears locked (hence no smoke visible up front) he then lunched the downshift at the same time. And the engine suddenly going to idle is perhaps going both feet in, with the rears locked. Could the rears locking been brake failure? Perhaps. But more likely a result of suddenly unloading he back end by hitting the pedal too hard, combined with the putrid rear E30 suspension
Yes, for this reason, IMO it was driver induced.
Not sure what Our Little Friend posted again, I am sure it more of the same BS![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
Yes, and speaking of the wonderful NNJR folks, I will return in September to the Glen with NNJR for their Advanced Event as as the event coach, available to all participants, just like last year.![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
#231
Whenever I've locked the rears I've always had copious amounts of smoke visible in the video in the inside and outside rear view mirrors.
I go back to what the driver wrote and by looking the lack of deceleration apparent in the video. The rear side to side funniness could have just been from the shift w/o brake involvement. Or maybe he thought he was on the brakes and was not - still ends up looking like failed brakes.
In the end, all it proves again is **** happens at the track. Don't try put your feet on the dash and wear a HANS.
-Mike
#232
If the rears were locked, how did he keep it from spinning as the car was turning right at the time?
-Mike
-Mike
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
#233
I just watched it a few more times. you can clearly see the speedometer in the early part of the sequence, then upon "lock up" or brake failure, the speedo, is still registering speed.... if you lock up, you would see the needle go to zero. it doesnt
i still think the speed hitting that wall is much more indicative of brake failure than lock up.. maybe we will never know.
#234
#235
It will be interesting to see what the other "coaches" see.
Personally, i do think it was brake failure due to the lack of smoke, sound and movement of the car during steering inputs (generally lock up, and nothing moves and it makes a distinct sound) also, he hit the wall with such force and speed, instinctively, it would seem even lock up would have slowed the car down more. i don't think going into that braking zone was much over 80mph.
#236
Mark - you have typo's. I thought you were precise? Sent it to to BMW guys I know. Friends of Rogue. It still looks like weight transfer to me. I'm at the track alot. Never saw any BMW brake failures. Corvette, Ford Shelby, Camaro, Mustang and others. Never saw BMW.
#237
that seems possible, but hard to imagine... lock up would be more believable, but the car doesnt seem to respond like its locked up , front or rear.
sounds about right, but this Bmw seemed to be a lot slower at the 300ft marker where he lifted and tried to bang a downshift. i was going off engine speed of that gear he was in, where you could see the speedo clearly earlier.
Sorry about the typos.. trying to work and out of the corner of my eye, partake in this discussion. had something hot i needled to be more precise with.
weight transfer doesnt happen unless you have a lot of grip. ive only seen brake failures when the lines burst. or pad knock back.(or pad come apart)
bmw, stock brakes , are very similar to mustang , porsche, single piston calipers. sounds like this guy had the good stuff.. St40 or better if i remember. those calipers dont fail often if ever. the fact that he didnt find any postmortem issues like blown line , etc, makes me wonder about the brakes failing too. but, the fact remains.. he didnt slow much and didnt seem to lock up.. maybe we need to get some examples of lock up on a turn like that and see how the car reacts and sounds from a similar speed.
#238
I'll be at WGI in two weeks, but I'm not volunteering to lock up on Turn 8 so you guys can collect data. ![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
I will be paying more attention to the runout in that corner. I thought there was a fair amount of distance (much better than many other places at WGI). But it may be similar to the runout in Turn 10, a lot if you leave the track at mid corner, not so much if you leave the track at track-out.
#239
#240
Groundhog day. So look at the turn before how he lifts in the turn and the tires start talking as the car is pushing.. Back starts to come around slightly. The next turn, with the unbalancing of the car- weird shifting before braking & going to neutral- (clutch depressed )as well as late braking & steering input? That would transfer weight to the front- unloading the rear and just pushing the car off the track. The wiggle at 31 looks like the rear just lost contact with race surface from the weight transfer? Good morning ..
