Can you remount MPSC's "inside out"?
Trying to get some extra wear out of my MPSC's. I very slighty corded the extreme outside edge of a rear tire at a DE this weekend. Inside tread is still in reasonable condition.
Is there anything inherent in the tire design that would preclude remounting the tire's inside out? I used to do this all the time with my Kumho Victoracers and would get an extra event or so out of them, but the older R1's were asymetrical in their design and flipping was a "no-no".
I know the tead pattern is different, but after a few sessions I suspect the remaining tread blocks that were on the inside would be worn down so the tire would be consistent across it's entire face.
Anyone do this yet?
Thanks!
Anyone do this yet?
Thanks!
King of Cool
Kim,
Any quesstimates how many cycles you have?
I was probably doing similar stuff as you last time at Sebring so I'm wondering whether I have used all the cycles I have (after about 3000 miles & maybe 40 cycles I still have little thread left)
I "flipped" before the wear was too much and they worked just fine. I did it after I was told by many others with more experience that it worked!
I didn't do it for a corded tire.
Originally posted by Silver Bullet
I've been told that many have flipped MPSC's on the rims and they worked fine. However, I wouldn't use any tire that is corded anywhere.
Also, as I found out on Saturday at Laguan Seca, if these tires have a lot of heat cycles on them, they are worthless anyway. I was pushing and sliding all over the place....felt more like a WRC event....
I wasn't implying I would run on a corded tire, just wanted to know if they could be flipped to extend tire life.
I got a more agressive alignment prior to this last event (-2.5 front, -2.0 rear) so I suspect future tire wear will be more even.
Your comment about the heat cycles is interesting. Previous discussions on this forum seemed to indicate an extended life for the MPSC's. How many heat cycles are you talking about?
From talking with a Michelin engineer you do not want to run these tires to the cords. There is a layer between the tread and the cords and it is not very grippy. Once your laptimes start to diminish significantly your MPSC's are probably garbage.
You might also think about running more camber. It is a compromise with a dual purpose car: either wear out the insides of your street tires, or the outsides of your track tires. Someday someone will do the analysis and determine the camber setting that optimizes wear of each at the lowest cost compromise...
Brandon
Brandon
Technical Specialist
Lifetime Member
Lifetime Member
Brandon
Brandon
I have a dual purpose Carrera and run -2.5" at the front with 225's front for the track and 205's on the street. I have driven about 5k miles on my current set of street Kumho's with no noticable wear. My trick has been to buy the hardest street tires and to make sure the toe is set close to 0"
Read this:
http://www.tirerack.com/tires/tires....ilot+Sport+Cup
"On the outside, the Pilot Sport Cup uses dual zone tread compounds with the outer shoulder compound optimized for dry handling and the inside shoulder compound focused on wet traction"
Now you make the decision on whether you want to flip mount the M's
