SmartyCam HD review
Basic Site Sponsor
Basic Site Sponsor
Received 2,799 Likes
The regular SC (all-in-one) has been discontinued. The regular definition SC GP (separate bullet camera and recorder) are still in some dealer's stocks, but the HD is the new-new thing. An HD version of the GP may be out in a few months.
To add any SC to your MXL with the GPS antenna, you will need a CAN Hub (5-pin male plug on the end of a cable and four 5-pin female receptacles on a black plastic strip) to plug more than one accessory (in this case, the GPS and the SC) into the MXL's expansion port.
Make sure you update the firmware in the MXL and the antenna before you plug in an SC HD (and it would be a good idea in general).
Good luck!
Good luck!
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Basic Site Sponsor
Basic Site Sponsor
AiM specific. $60 Allows you to add more AiM accessories, too.
So has anyone used the HD as a stand alone? The docs on the website are unclear. It seems like the HD should have a gps thing in there so it can figure out your laptimes and do the track map , speed etc. on the embedded data on the playback. When you read the website is makes it sound like to do this you need the soloDL to be plugged in at a minimum? Comments?
When will they have side by side lap comparisons sync'd to data like Vbox? HD is a waste of time until AIM can do this. I say waste of time because AIM is a data system, and there are far far better video options that are cheaper.
Basic Site Sponsor
Basic Site Sponsor
Then, I used it with just the antenna and got lap times, lap count, track map, speed and g's. This was, for me, the best standalone mode without a vehicle connection.
The battery only lasts 75-90 minutes, but when acting as a slave, it gets power from the logger that is the master, or now you can get cigarette lighter cords or permanent wire power cords.
The killer app is paired with the Solo DL, which provides logging as well as sending info and power to the SC HD.
On your latter observation, I disagree completely. The intelligent video (data overlaid real-time on the video) of the HD is what 75-80 per cent of the people use that I work with. The same with VVBOX Lite, but the video is SO much better quality (and have you priced the VVBOX Lite HD? NO data overlay on that, only synced) in the AiM SC HD, it's not even funny.
Few people I know will take the time to sync the HD files from the less expensive video recording options you cite with the data, it's just too much work for most.
People want to pull the chip and watch the speeds, g's, times, throttle position and brake pressure. At least most of them do.
When people want to dig deeper, then they open the data files. No question the side by side VVBL analysis is good, but there are benefits, pros and cons to each system.
I agree AiM is behind on the data/video synced window, but now they are ahead in "real-time rendered" data overlaid video.
Clearly, you haven't yet tried to set up MoTeC to do this. Epic fail... In usability, anyway.
Oops, Peter answerd this already!
My team had a race last weekend and we used a Smartycam HD for the first time:
Pretty impressive stuff + it acts as a GPS antenna for the installed MXL dash so we have the laptimes on the dash too, without using a beacon.
Basic Site Sponsor
Basic Site Sponsor
This does require, here in the US, the purchase of the separate GPS antenna along withe the SC HD.
Then, just plug the CAN cable into the MXL from the SC HD and you're set!
Hi Joe
Tell your friends that have the SC HD with the short cable (2 M) that I'll swap it for the 4 M cable if they bought the unit from me. The first batch was 2M cable only. Just have them e-mail me, I have the 4 M units in stock now
