Andy Lally advanced driving clinic
#106
Mike, the lateral accel info is useless IMO, get rid of it and put a time delta in there to show where the time is drifting, see my screenshot, it's the very bottom graph. That will make it easy to see where you lost the time. But eyeballing it looks like you let someone pass around 12-13 (green), and then with the red, something happened in the front straight. YOu would be amazed how fast you bleed time in the faster sections.
#107
As Jacy said, it is extremely useful to see where you are gaining/losing time in a comparison.
#108
In the Green 2:07.814 lap, you lose 1.8s with the huge speed drop letting the vette by.
In the Red 2:07.708 lap, you lose 1.5s with the huge speed drop at the apex of T14 (and another 0.7s with lost time down the front straight).
That is where the vast majority of the delta is.
#109
I've got some of my own data of me falling off and climbing back on this plateau from last month, I'll have to see if I can generate some plots like this with it.
ETA: That green T12 plot indicates I need to practice more off line. At that point I knew the yellow Corvette was going to catch me very close to the apex of T12 and I didn't have the confidence to keep the speed up knowing my path through T12 was going to be a rim shot. Staying on the inside and giving a point by to the right just didn't make sense at the time because I didn't want to ruin the yellow car's obviously good lap.
-Mike
#110
You can see this as the peaks of the blue lines slightly higher and to the right of the peaks in the red lines, while the troughs line up much better. That seems to be where you're losing the rest of the time.
Just my non-expert $.02
#111
Enjoy! Try not to drive yourself crazy with the data
You can burn a lot of time looking at the squiggly lines, but the key is to find 2-3 things to work on next time out.
Oh and AIM products happen to be on sale here: https://rennlist.com/forums/showthre...errerid=100868
I think your car is a bit too old for the DL to be worthwhile but I love my AIM solo and missed it when I was out without it this weekend when it was being lent out. I hated thinking I had a fast lap and not knowing for sure!
#112
Rennlist Hoonigan
which cost no drachmas
I'll make some notes on the data here, but it's important to look at your body of work, not just one fast lap. You'll find much more useful room for improvement if you look at multiple laps to see what your personal trends are. You can then figure out where to look to improve, versus looking at one lap where you had a stroke of brilliance and put together a fast lap.
#113
#114
Rennlist Hoonigan
Note you lost a whole second on the first corner. That is your first order of business.
#116
Thanks for taking the time Matt. I've got video of both sessions and I'll take your notes and review. One issue with that first plot is the turn references are off. Probably doesn't mean much, but it helps me get in my mind where the various things occurred on the track.
1) Yes, Andy was exceptionally good at maintaining entry speed. I'm the opposite, entry speed is one of my weaknesses. He maintained acceleration much deeper into T1.
2) I believe the "stutter step" on the brakes is actually an upshift as it happens just before T4. There is another one on the 3-4 upshift at the exit of T6, which appears to be at T8 in that graph.
3) The over-rotation is in T6 and I remember it :-)
4) Yes, Andy was taking a very different line through T8-T9. He stayed mid-track at the exit of T8 where I've always been far left. I asked him about it and he said he was trying to maintain entry speed and the forcing the car left would slow it down. He did the same thing at T13, which shows up as between T11 and T12 on the graph you used.
Again, thanks for the markup. I've attached a plot with corrected turn markers.
-Mike
-Mike
#117
The Penguin King
The Penguin King
[QUOTE=TXE36;10901160]He got four sessions in. Three in my car, one in Martin Cain's. I rode with him while he was learning the track, set him out on his own to put down some hot laps, and then got back in with him once he knew his way around. His ability to quickly learn the track is one of the things that really stands out.
#120
It's been great to see all of the videos of Andy driving the track. Sounds like every one had an incredible experience. I know I love TWS. What was Andy's impression? He's driven all the great tracks but did he enjoy ours?
A couple of other questions/observations:
- The common line for us DE'ers through Turn 1 is to get to the Yellow box and turn in. I never saw Andy go that wide - in fact it seemed like he kept two wheels on the inside of the blend line through many of the laps and at much faster speeds that I can manage even taking this turn wider. I saw a picture during the track walk explaining his approach - would you guys care to elaborate more on what he sees and what he's trying to do there?
- Through 8, I have always brake just before turning into 8 and come in close to inside (left of the contact patch) and then dart downhill. I see that Andy basically ignores turn 8 and appear to jab brakes, downshift, just before 9 instead.
Eric Foss did something similar in the Wolf going CW where he would extend the end of the front straight to entrance of 14 - ignoring 15.
