cost to build spec 996
Old 10-11-2013, 06:13 PM
  #361
coinboy
coinboy's Avatar
I run a 1999 996 C2 - SP996 at 2,850 lbs w/driver and the stock calipers and master cylinder work great for me.
I run PFC - 01 pads and SRF fluid and do not have any problems.
Old 10-11-2013, 10:19 PM
  #362
philooo
philooo's Avatar
good to hear that stock works when properly setup/driven
I will try once more to bleed this thing right, we'll see.
Old 10-12-2013, 12:27 PM
  #363
good hands
good hands's Avatar
Plus 1
I run a 3.6 996 in gtb1. Stock brake set up with pagid blacks and srf. Brakes are more than adequate.
Old 10-12-2013, 12:46 PM
  #364
KaiB
KaiB's Avatar
Yer giving Bryan WAY too much credit!!!
Old 10-12-2013, 01:00 PM
  #365
GuyIncognito
GuyIncognito's Avatar
what cooling ducts are you using?
my car changed dramatically when I put the GT3 cooling ducts on the front. before that they would overheat and go into ABS after a lap or two.
Old 10-12-2013, 04:38 PM
  #366
coinboy
coinboy's Avatar
Ha Ha
I'll see you at ECR in a few weeks buddy!
FYI: ECR is hard on brakes, bleed well. I would not want you crying about brake problems!
Quick Reply: cost to build spec 996
