HANS device 2005 model modification
LIke I said, I have been using the same setup as you (old HANS and 3" belts), but with a taller seat. Been there, done that. I let out the belts a little bit when I got the HANS, and that cured all ills. Trust me, there's no investment, just give it a try. And the sliding tethers will be the best $40 (off of memory) you'll spend.
Trust me, I am trying to help.
It took TWO threads started by Mark on the exact same subject for someone to REALLY get to the truth.
BTW, Mark, that sticker has to be counterfeit. My HANS, manufactured in March of 2005, has the winglets.
And still using a seat that was involved in a MAJOR crash, that broke your ribs, is retarded. To be clear, this is not a personal insult. I am not saying YOU are. I am saying your behavior and incredible intransigence is.
You make several references to friction. Friction means nothing in this context. Crash forces are orders of magnitude higher than any resistance from friction. Its the fit that is not correct, maybe due to where the adjustors are, maybe due to the layback. This is also made worse by the wire, as its rerouting of the belts only creates slack that will be let out as it deforms under load.
You stated in the other thread that you are getting a new seat. Why are you still trying to make the one you have work at all? It is manifestly unsafe, and you seem to be the only one in all of Rennlist that thinks it's even remotely OK to use in anything but a video game simulator. Before you do anything else, start with a proper seat.
I'm a die hard budget racer, but God help you if you "save" money by reusing that seat.
So, based on somones suggesting "D" rings, i used an old kitchen drain keeper ring, that is 3" diameter to hold the belts together , just before they go into the seat openings. this is feeling like it will work
Good lord, Mark- and you think the Hans is poorly engineered?
[quote=RickBetterley;9370675]
Again, contrary to the contrarian, you are right. the All knowing VR is usually wrong, but will never admit to it. He feels so much better blurting out "conspiracy theory" when his knowlege on the subject doesnt carry enough weight to back up his insults.
as far as the ring, it doesnt create slack as it has very litle spring pressure to creat slack agains thte synching up of the belts. it deforms to allow the belts to be at full tension. i guess i could use a rubberband to do this function, the net result would be the same. just trying to deal with a design flaw that HANS had with the device before the wings. ive heard that this is a common method. ribber band or some kind of ring .
Thanks for the input. Ill have a low key race that Ill run before i get the new seat for this season.
the HANS is pretty interesting technology, certainly a lot more convenient than my old 2001 hutchens device that looked like something out of a parachute kit. it was such a hassle i wore it way less than half the time. I think the HANS is a good regulation, since in a crash, all the saftey stuff in the world , prior, would do nothing to keep you head attached to your shoulders. almost better to fly rhough the windsheild than have the body strapped in and your head only held on by some skin, muscle , tendon and cartilage.
Scott
Rennlist Small
Business Sponsor
As for the HANS device you have, it was made before 2005. The early devices were pre SFI stickers and a number of people sent them back to get the sticker so they could run with organizations that have required an SFI sticker, not just an SFI device. I've seen a number like that and it's a red herring in the situation. The wings aren't going to change anything regarding the problems you are having.
Or you could just get a Hybrid Device and not deal with the problems you are having.
