ASK THE COACH
#2401
This really makes very little sense to me.
When turning a wheel, you have the most control and precision if both hands are working together equally. Hands do that, by nature, more effectively. Trying to vary input from one hand to the other is harder to do and is more error prone. It takes more brain power to do to which is not what you want.
This will result is the least amount of fatigue as well.
I agree that it is not something that you can, nor should, consciously try to do, but I suspect that we all do it, just because of the way we are built, because of the relationship between our bodies (arms) and the steering wheel; top arm extended and lower arm bent, closer to the body.
Yes, driving is definitely a 2-hand activity, but I have confirmed, in my own driving, that both hands work slightly differently depending on whether they are pulling or pushing.
#2402
I find that my shoulders and arms are less tired at end of day if I try to pull down with right arm when turning right and vice versa. I probably have all kinds of other bad habits and I certainly have to work hard to soften my grip which may contribute to fatigue.
#2404
#2406
Look at what happened when the FIA mandated a single hand control for the clutch versus the dual hand controls allowed last year. Universally, the drivers are having much more difficulty getting consistent launches.
Why? Two hands working together have much more feel and precise control than one.
#2408
Interesting responses thanks
... I ask as the Instructor at the PSDS at Silverstone Experience Centre said what Thundermoose did above i.e. pulling down w right hand to turn right (with left hand stabilizing and helping) and visa versa for left turn.
Claimed it was easier movement for the muscles (this was also linked to seating position with arms bent not straight) and hence better/more efficient - pecs stronger than forearms etc
#2409
We have a very well respected LSRPCA classroom instructor who advocates pulling down, but frankly I've never been able to do it consciously. I just steer the car. It's not like it takes a lot of effort with power steering. A manual rack may change things.
As others have indicated, I do better if I loosen my death grip on the wheel which ironically I find easy to do without gloves. It looks funny when I really practice it as I drive around pinkies up. I know I've really blown this if my hands are sore at the end of the weekend. Hmm, I wonder if I could add a steering wheel grip sensor to my data?
I've got some video of this, but frankly, the "standard" is what I observed when VR drove my car years ago:
Traffic didn't cooperate very well, but it shows the point.
-Mike
-Mike
#2410
Rennlist Hoonigan
which cost no drachmas
#2411
Give us a break. Different scenario. Some tasks can be accomplished properly with one hand only. Throwing a ball is another example.
Power aside, people have more control and precision swinging a bat or a golf club with both hands/arms.
#2412
#2413
Thanks Matt & Winders ... One thing about the light touch approach that worries me if that if front wheels hit a divot or dip under braking and wheel jumps out of your hand .... Especially dips in middle of fats sweepers etc .... I try relax my hands on straight but prefer a solid grip in high speed sweeps or coming into the big braking zones
#2414
Assuming you know what you are doing on the track, you know when the steering wheel may move with some force and you adjust the grip pressure accordingly. Oh, make sure your bumpsteer is not too far out of whack too.
#2415
Whoops, posted the wrong one. Thanks for the invaluable input from both.
Apologies to the last post.
For what it's worth, I wondered about this as well and lean toward a balanced application dictated by circumstances. Didn't think others were looking at this as well.
https://vimeo.com/144095076
