Brake fade, how to prevent it........
Old 04-21-2011, 12:37 PM
  #61
BostonDMD
BostonDMD's Avatar
Originally Posted by Adam@Autometrics
Perhaps I missed it, but I didn't see if he mentioned whether the pedal was soft or firm when the car would not stop. Overheated fluid will give a soft pedal (and it gets progressively worse, so it doesn't sneak up on you), but overheated pads or glazed discs will give a firm pedal but little stopping power. On the Koni 997s (before going to motorsport ABS System) occasionally we'd get ultra-firm pedal with almost no stopping power. Overheating fresh SRF (even with PSM) is not easily done, and orange pagids are generally good for street tires, so I wonder if it was the PSM/ABS issue.
Pedal was firm with no stopping power....
Old 04-21-2011, 02:36 PM
  #62
mark kibort
mark kibort's Avatar
With oranges, I would have the same issue but only after an engine change got 50more HP and 10mph straightline speed at a fast track near you. it would stop, but not where I wanted it to stop. so, larger rotors and "Blacks" solved the problem. generally, over heating the brakes can be solved by a technique, rather than a mechanical change, unless you are truely at the limit of the pad and rotor combo. I cant tell you of how many race days Ive been at, where a slower guy in the group will be boiling fluid, or complaining of lack of brakes, stopping power, fade, etc, only to see them with larger brakes, better pads all producing 2-4 seconds a lap slower times.
Moving to blacks from ornanges, was a pretty significant change.
Old 04-21-2011, 03:29 PM
  #63
himself
himself's Avatar
Sounds like Ice mode. Hit the search button and read up.
-td
Old 04-21-2011, 04:00 PM
  #64
Adam@Autometrics
Former Vendor
Adam@Autometrics's Avatar
-td
+1 That's what I was describing with the Koni/Conti 997
Old 04-21-2011, 04:52 PM
  #65
kurt M
Mr. Excitement
kurt M's Avatar
It is all in the missing or missed details. Rereading the OP I see onset was on the last lap and not discribed as getting worse over time. Paolo did the brakes go bad and come back with little warning or did you note them gettign weaker?
Ice mode is sudden onset. Heat related brake fade gets worse as you continue.
Old 04-21-2011, 05:03 PM
  #66
BostonDMD
BostonDMD's Avatar
Option #1: brakes went non-responsive suddenly, no prior warning......
In a prior session with an instructor in the car it did it once, at the end of the main straight, (but not so unresponsive as the last session), then it all went back to normal.
In the last session, the non-response was huge..... I came so close to the tire wall that I didn't want to chance it again, hence, packed up and left......
If anyone cares to share the cliff notes of "Ice mode", I would appreciate it....
Old 04-21-2011, 05:13 PM
  #67
utkinpol
utkinpol's Avatar
Originally Posted by Matt Romanowski
I could be wrong, but I beleave it uses all four wheels. According the manual (http://www.porsche.com/all/media/pdf...ayman_PCNA.pdf page 63) it says it brakes each wheel independently.
You're right on the front brakes normally causing fade as they do the most stopping. Overall I don't think it matters which caliper boils the fluid - it all works off the same master cylinder. If you have dual MCs, then it might be different, but I'm guessing it would still create a soft pedal.
i have no idea. i was told once by somebody on a track that a good way to see how much PSM engages is to check wear on rea pads - if they go faster than fronts then it is PSM so i 'assumed' PSM kicks on rear only. apparently that was a wrong assumption based on what is in that PDF. interesting info, thanks.
Old 04-21-2011, 05:15 PM
  #68
kurt M
Mr. Excitement
kurt M's Avatar
Sometimes you have to pick and tease the important info out for a correct answer.
I hate to say it but "search" is your best first move on this one. Lots of good info already typed.
Old 04-21-2011, 05:46 PM
  #69
Matt Romanowski
Rennlist Hoonigan
which cost no drachmas
Matt Romanowski's Avatar
Sounds like the correct answer is the ice issue. I agree search is the best bet.
Free advice is worth every penny you get. Best way to know how much PSM is working is to feel it or watch that little PSM light. Anything else is just watching the after symptoms.
  #70
sig_a
sig_a's Avatar
These products may pinpoint which brake component is getting overheated. The blue Thermax sticks to the caliper and the Tempilaq G paints onto the rotor's outside edge and/or metal backing of the pad. Manufactured by Tempil South Plainfield, NJ.
Old 04-21-2011, 06:19 PM
  #71
BostonDMD
BostonDMD's Avatar
What do you mean "search"?
I guess I have been spoiled here on RL over the last few years.....
I have been accustumed to just ask a question and people would just spoon fee me the right answer....... now you want me to search?
Joking aside, thanks for all of you guys' help........
I am off to "search"......
Old 04-21-2011, 06:50 PM
  #72
GT3 Techno
GT3 Techno's Avatar
I experimented this in my Cup car last year and bleeding the brakes resolved the issue. There was probably air bubbles in the lines in my case.
Old 04-21-2011, 06:55 PM
  #73
gums
gums's Avatar
So true, Paolo, so true!
Same for my kids; "Dad, why in the world would anyone waste their time going to a library for anything?"
Old 04-21-2011, 07:25 PM
  #74
MUSSBERGER
uninformed gas bag
(contemplating on whether gas bag is one or two words)
MUSSBERGER's Avatar
That's why I asked in post 12 if it was engaged.
Old 04-21-2011, 09:40 PM
  #75
utkinpol
utkinpol's Avatar
congrats on your article in panorama, it just arrived today.
Quick Reply: Brake fade, how to prevent it........
