Sebring: Boxster S New Personal Best
#31
Nice going. Sounds like that's a great time you achieved.
A couple of questions.
-You seem to stay in a higher gear through some of the corners which to the ear sounds like the car
labours out of the next corner a little. Was this done on purpose or had you downshifted in the past
and found it to be slower?
-What Hoosier slicks are you using?
-Agree with VR...you need some Sunnies or a tinted visor.
#32
is this not the shape of most of the 3.6 liter 996 engines hp curves?
https://rennlist.com/forums/996-foru...96-dyno-s.html
Boxter gear spacing from 3-4th gear is: 7000rpm to 5600rpm. look at the hp drops in that range.
from 7300rpm to 5900rpm would be the drop at 300rpm higher.
the moral of the story is that , by shifting early , at any rpm below redline, you are losing about 40hp.
Transmission
Gear Type 6 Speed Manual
Final Drive 3.44:1
1st Gear Ratio 3.82:1
2nd Gear Ratio 2.2:1
3rd Gear Ratio 1.52:1
4th Gear Ratio 1.22:1
5th Gear Ratio 1.02:1
6th Gear Ratio 0.84:1
Transmission
Final Drive 3.44:1
Mark...are you aware that redline is not the HP peak in your graph? redline appears to be 7,600. The HP peak appears to be 200-300 RPM under that.
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
Pretty much what Viking and I said....know what I mean?
Professional Racing and Driving Coach
#33
So, even with you 3.4, do you see the problem with short shifting even 2-300rpm?
If the torque is flat from 4400rpm to 6000rpm, that means the HP is rising at a 45 degree angle. so, as soon as you short shift, you loose 50hp, which is a reduction of acceleration, because you are in a taller gear now with less mechanical advantage.
[QUOTE=Ritter v3.4;8275075]
Mine (3.4L 996) is not that steep. Peak hp is @ 6700 and is down 50 hp @ 5k.
TQ is pretty flat from 4400 to 6000.
#34
Sure. Im absolutely aware of that fact. So are you still thinking its better to shift out of the gear you are in as the HP starts to fall, or before hand to save the engine? I just want to be clear on what you are suggesting.
So, why are you rolling your eyes, even if the HP falls off as you pass THOUGH 7400rpm, it still pays HUGE dividends to carry the RPM to redline. Do you know why?
This is because shifting to the next gear gives you MUCH less HP at the same vehicle speed, thus giving proportional less acceleration. Do you not agree??
your seat of the pants "feeling" cannot be trusted. It might feel like you are not accelerating any more, but the next gear gives an even greater reduction in acceleration. make sense??? This is someting I counted on my BMW racers to "feel" so I would have a distinct advantage in our races. It wasnt until later when the races didnt mean as much , did I educated them on this common misconception. After much push back, they finally got it and the result, their lap times improved. Not a big deal for DE'ing, but if you are racing or wanting a better lap time, it is a big deal.
edit: I assume you are referring to the graph of the 3.6L 996 showing redline or end off the dyno run at 7500rpm.
Ill conciede one thing, it doesnt always have to be redline. redline is too general, lets just say its often well past max HP. Using seat of the pants wont tell you anything here, you need to know your engine profile (hp curve) if you are serious as a racer (Or coach) to optimize straight line speed anywhere on the track. It may seem like shaving hairs, but in this regard, its as important as braking zones, cornering and exit speeds and driving line. If dont KNOW it, and using seat of the pants or misinformation, you are guessing at what is best.
#35
No, i never use the seat of the pants feelings to determine shift points. I always use dyno sheets, especiallly when racing a car of mine or someone else.
countless hours on dynos dont prove anything but helping maximze HP performance, and safety of their engines. I have minimal dyno tuning time each year, mainly to just make sure the engine is safe from itself. If I wanted to , I could spend the extra cash, optimize the power and pick up about 40 more HP by most approximations.
Now, to answer your other question, I visit the dyno 2 times a year, if there are no changes. More if I have changed something like a cam or intake mod. I dont "rely" on the web for any information I use in my racing. what do you mean by that? the point is, on the topic of maximizing acceleration, nothing else., it never pays to short shift, ever in a car equiped with an engine with a rising, peaking HP curve. Im lucky having a V8, its a very flat HP curve, so I have the luxury to short shift slighty, and have it not impact performance as much as it would, a flat or inline 6, generally. in other words, my short shifts
end up at near the same hp post shift as pre shift, but this is generally unusual.
so, my main point to you is that I am bashing the "seat of the pants" opinion. I can do this, by saying there is NO basis for it to be true. And can prove it very simply by common logic based on the common shape of the engine HP curves for the car in question. I also can give a reason to why it might feel faster or better to short shift, but those feelings are incorrect and certanly can be proved by data aqu. if a comparitive test is done. If you dont have the same HP at any given speed, you dont have the acceleration rate at that same speed either. just basic physics. By understanding this, VR would be a better coach!![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
My point was really that you seem to bash the seat of the pants opinion which I believe is all you use in your own car. So you rely on other peoples data found on the www in which you really don't know all the parameters to argue with others that are using data and spend countless hours on dynos.
So......... please answer my original question, what data system do you have in your car?
Oh, and here is one more, how many dyno pulls or hours on a dyno do you have on your car in say the last year ?
#36
![](http://www.gifbin.com/bin/1232550426_worf%20face%20palm.gif)
#37
Now, we are going racing at High PLains Raceway, with you and a 300rpm earlier rev limiter. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Seriously though, Its still bugging me though. what did you mean, or does it matter with the 3.6 liter engine having the HP fall off 300rpm past peak HP. Help me understand the point.
#39
Remember when WCGT went to Sebring with the ""Cheater" Caddies. they broke into the 2:10 range, if I remember correctly. On DOTs none the less!
I forgot what tourng was doing, but they seem to be a good bench mark for cars we can at least relate too performance-wise.
(I think 2:23 comes to mind)
#40
Deputy Dog... you kill me!
Mark, now I don't understand your last statement about the GM Caddies, who according to you turned a 2:10, how is a fully tube-framed factory "touring car" eeeeerr racecar a good comparison to a showroom purchased, aftermarket modified street car? I lost ya...
#41
Deputy Dog...I've some some kiddie carts or a Big Wheel for ya!
#42
The point was that a well tuned and driven GT3, on slicks should be pretty close to the WCGT times. GT3street, a few seconds behind that. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
(at least its like that at Laguna seca for WCGT, GT3's, and GT3 streets)
The fact that the WC touring cars on 245 DOT toyos can run 2:22 with less than 300rwhp, sets the bar, right?
#44
No, he really is serious, that's what I don't ever understand.
Mark, you can't say a short shift is faster or slower in X car with X dyno graph without also using a gear chart for the car to REALLY determine where the power will jump to. Then you could logically argue your point. The stock gear charts are readily available on the internet for you to play with.
I now need to go over the data from this weekend to determine some real world situations. Have a good evening.
Viking
Viking
#45
Viking
Viking
