View Poll Results: Face Shield or Sunglasses?
Voters: 94. You may not vote on this poll
I know this topic has been discussed, but I'm about to invest in painting my new Stand 21 helmet and need to make a decision whether to paint with a visor, or go to a face shield.
I've been racing with a visor and wearing Oakley wrap-around sport sunglasses. I just cook with the visor down and haven't made the commitment to get used to it. I'm just curious about the percentages, hence the poll.
Thanks for participating.
Also, lugnuts pass thru windshield and sunglasses, but not visors.
We've worn tinted shields for years and have never had a problem. Leave the bottom of visor slightly open and you'll have no fogging.
Drive an SRF and the choice is easier!
I wear prescription glasses, so I always had something on my eyes. Clear or sunglasses. And inside a street car, I usually kept the visor up for fresh air. No more in SRF.
Echo what Glen says!
Here is the main reason why and there is no arguing with this! Charles Espenlaub is a good friend of mine who has been an inspiration to me. This happened in a MX-5 cup car which is really a street car turned racecar exactly like most of the cars driven on track by everyone on this forum. A visor, open faced helmet, shield up with sunglasses, and without a balaclava would have ended in severe facial damage and more than likely death in his case. Charles walked away from this with some minor burns and 2nd degree burns on parts of his hands. Think about it next time you get in your car
THE MOST IMPORTANT RACING ARTICLE YOU WILL READ
Damn! In four years of participating in every POC race event I've only seen one minor engine fire...But one photo is worth 1000 personal experiences in this case.
I guess I need to make the adjustment and go to the face shield.
I wear prescription glasses and have the shield in place, but usually up.
In a fire it would take less than a second to get the shield down. I have been trying to drive with the shield down to see how well it works for me (fogging problems initially) as I realize that if out cold from an impact, you can't pull down the shield or push the fire button.
I switched from an open visor to closed because of that incident and I wear glasses. No problem with fogging just get a helmet with decent venting
I always wear glasses inside my slightly open face shield. Whenever feasable, the shield is down.
Further, if you've ever gone through the speedy dry with an open visor, you won't do it twice.
Some of the newer helmets are designed so that even if you leave the visor open a little bit at the bottom there is less chance that it will get forced open in an impact. I am considering the Bell BR-1 as a replacement helmet and the description says:
In addition, the BR-1 features our new SRV friction shield system. This new system has a slide mechanism that allows the driver to adjust the tension on the shield allowing for multiple opening positions. When properly adjusted and in the locked position, the SRV systems helps reduce the possibility of the shield opening during an impact.
