996 cars only: Hose clamp must be installed around oil filler cap - ?!
NEWB ALERT!
CVR tech rule.... I know its plain English but I am doing something wrong.
Got the metal hose clamp from the hardware store with a screw that makes its radius smaller. Got it around the radius of the filler cap and it slips off when I tighten it.. I cant get it tight enough to make the cap stop spinning...
whats the procedure here? I am probably over thinking this... pictures anyone?
What do they have you put on the radiator tank cap or the gas cap? What's the point of that rule anyways? You guys losing your caps? Sounds like it will just cause cracked oil filler pipes, which are not easy to replace!
The CVR tech sheet reads: "996 cars only: Hose clamp must be installed
around oil filler cap."
This is based on a TB from Porsche when they noticed a POTENTIAL failure of the filler cap (coming loose & falling off) on the Mk1.
A simple hose clamp... placed around the filler cap tightened firmly (still allows removal of cap) and then you are set for the SPIRIT OF THE RULE.
These filler caps really do not come off... BUT, we are in a world of WHAT IF's and litigation.
CNY Tech Inspector....
when putting on the clamp, you should try to make sure that the screw part is new the air filter housing body so that IF it starts to move, it will be held against it.
I agree that it was never an issue for me, but I put the clamp on as an added precaution. I wouldn't want a major issue that could have been avoided for an inexpensive clamp.
steve
steve
Just had my car teched and the box next to this is marked with a minus "-" not an "x" - if I put this clamp on before the event, will the tech at the event give me a hard time about the tech form not having the "x" in place?
thanks
I'm in....
No. That's the purpose, so you can fix any deficiencies.
King of Cool
When you twist the cap on completly it seats against an "O-RING", thus creating a slight compression.
The thought process behind the hose clamp is that it will create higher friction... I.E not allowing the cap to vibrate loose...
All cars with a yellow fill oil fill cap should have a hose clamp. This includes 964, 993, early 996. The 993/964 cap gets soft and leaks oil the 996 cap comes off. This rule is for your benefit.
I am the CVR tech chair. As far as giving you grief we try hard not to do that
