Let's go back to the basics......
First off, I don't think you were on the tail of the boxster enough to try that dive-bomb move... you're too far back to try and out brake him.
Second, you leave the wall at around the 200 marker, and head straight down to the apex. That's a pretty early turn-in approach that will cause you to really have to slow down the speed of the vehicle because you'll need a lot more rotation 1/2 through the corner.
Third, you bet against physics. Look at your G forces on the lower left... that's your braking force. You're braking quite hard at the apex (1.5-ish Gs). Under this hard braking, you go over the curbing (upsetting the car) and give it some steering input. Probably, a tire or 2 locked up because you exceeded their traction limits, and then it was all over for you.
If you'd been able to do a smooth brake release and counter-steer more and sooner, you might have been able to correct the car's trajectory to the outside of the track, regain composure, and continue on - however, that trajectory might have put on on a collision course with the boxster.
Truth. And they're not the only ones who do it.
Professional Racing and Driving Coach
Lifetime Rennlist Member
In short - bad line. Maybe the Boxster forced you, maybe not.
When you make the classic inside, out-braking pass, you go straight UNTIL you get to the normal line and blend into that. That makes the corner an increasing radius. You made a VERY early turn in, and made it a severe decreasing radius. Hitting the curb also didn't help but I doubt you would have made it even without the curb.
Rennlist Hoonigan
which cost no drachmas
Slow hands. The car is starting to develop too much slip angle right before you got to the curb. You didn't start countersteer until the car was getting away from you and then you stuttered with it. The opposite lock didn't happen until you where too far gone.
To me that seem like a big time dive bomb. You were 1-2 car lengths back when you tired the move which to me looks like you need to go in way deep. You went in so deep you outbraked yourself and was forced to enter the turn with too much speed for the line you were taking. The reason you went to fast of course was that you need to pull off the pass.
So in my mind even if the car infront was slower than you in that corner you pulled a move from too far back. Luckly to not take out the other car in all this.
There were at least 2 full car widths between you and the Box when you went by him....why ? Shy ? Didn't want to muss up your hair ? You were both wearing the same dress ?
Classic "fade in on entry" issue. You gave up all sorts of radius, and (as already pointed out), made a bee-line to the apex.
Dude, really.
When passing at corner entry, skin the guy you're passing. You should have been able to reach out and whack his passenger side mirror.
Use as much track as you possibly can. Some will think the "shave it" pass is overly aggressive, but it's really overly defensive. If the bozo turns down on you, it's just a little bump. Give him two car widths to get a running start...and you'll be headed for low earth orbit.
Dude, really.
Good advice professor.......
I guess I am a bit timid to get close, will try more skin passes on my next race.......
I probably was getting too frustrated of being pulled on the straights and then slowed down on the turns, but that is no excuse......
Will do better next time....... I promise........
Also, considering the late off line move, he could have interpreted that as not necessarily going to over take him, but actually going defensive against the guy behind you. Hopefully that made sense.
Hey Doc,
I think you have your X & Y accelermeters backwards on your video.
At the start of the video, it shows Red on the left side. I assume Red should be braking, but you're accerating there. In T11 and T1 it always shows Green. I think Red = Left turns, Green = Right Turns.
And when you're accelrating the white bar at the bottom is toward the right. Under braking it's toward the left.
