wheel bearing grease
What grease are you using? I am having trouble with Aluminum hubs and wheels bearing failure or pre-mature failure.
Thanks, Mike
Thanks, Mike
Part of the issue might be a need to have the hub "looser" than normal as it seems the hub is transferring more heat and therefore more expansion than the stock hub. As far as the grease goes the bearing engineer is recommending a Mobilith SHC 220.
Man of many SIGs
PM GregBBRD . He has extensive experience with this issue and may be able to help. I remember him mentioning this in a thread once before.
Neo or Redline,either are a great choice. I've also had good results with Amsoil 2000 Racing Grease. Krytox is really $$ like Steve said but it is indestructible. I can't imagine this is a lube related failure though...are you sure everything is in spec?
Is Krytox® compatible with aluminum?
There is no reactivity with aluminum at temperatures below 288°C (550°F), but is not recommended for use in equipment that has bearing surfaces made of aluminum.
Try Neo before resorting to Krytox. Krytox is pretty nasty stuff. Don't breathe in the fumes if it gets hot!.
You can get Neo here.
http://www.hrpworld.com/index.cfm?tp...ction=category
