iRacing and mac?
iRacing and mac?
I'm interested in running iRacing, but the Intel 950 videoprocessor in my macbook (about 3 years old) won't work. Anybody running a mac and iRacing successfully?
Thanks!
David
Thanks!
David
I run it on my MacBook Pro (2.4 Intel Core 2 Duo, 4GB ram) w/Bootcamp. It works OK, but I have to set the graphics options to as minimal as possible to get reasonable frame rates if I'm doing anything but solo testing. I bet it would run just fine on a later model Mac Pro tower.
Tom
Tom
I emailed iRacing, and they said they do not officially support mac, but have customers that run it. She recommended boot camp, and 2GB of RAM partitioned for bootcamp/xp. My friend just built a computer using the nvidia 9600 card, 2.5 ghz for about $450. I could trade up my macbook for about that probably, but it might be nice to have a standalone, dedicated unit that's easily upgradable over time.
He's also using the G27 Logitech wheel/pedal set, and says it's amazing. That's what they used as the demo at PRI (the older G25), but w/ a much faster computer, surround sound, flat screen, etc. What wheel set, and setup is best?
I also run iRacing on an intel based Mac. I have one the original Intel iMacs. I use bootcamp with windows XP installed. The biggest problem is the weak video card built into the iMac, otherwise it works like a charm.
...so I gues my new MacBook Pro will run iRacing just fine???
Yes, a new MBP running a boot camp partition will play most PC games without an issue.
I have an older MBP and I'm running a Win 7 boot camp partition. I've played games on this with less headache than my PC. Win 7 is great because it senses all of the Mac hardware (iSight, expansion ports, video cards).
Also, a nice feature of the Mac OS is that you cam create or wipe the boot camp partition without any effect to your main Mac partition. You CAN NOT make it larger though, without deleting the partition... So pick a reasonable size at the start. I used 50gb, but I have a 500gb drive...
Once you have made your boot camp partition, you can access it when booted up in Mac OsX using either Parallels or VM Ware Fusion. The latest VMware is ESP nice... They say you can play games this way too - but you can't (at least on a MBP) - it's way too slow.
Just my $0.02. Have fun
Anyone running iRacing with Parallels? Thats my preferred mode when I absolutely positively have to endure windows.
Well, my computer was stolen over the weekend, so now I've got several new (unwanted) options. I talked to a mac friend, and he said the laptop (even pro) video cards were not the same or as capable as what would come in, say, an imac because of sizing limitations. He thought the cheapest route would be to build a dedicated computer to run iracing, or get an imac, rather that getting a mbp capable to run iracing very well. As an experiment, I'm borrowing my mom's imac that has the nvidia 9400, and am going to install bootcamp/xp on it and compare it to my friends purpose built system.
I think I'm going to get the smallest mbp, but w/ 4gb ram, for my day to day stuff, and aim data software, and and try iracing on it. Then knowing what my friends system is like, make the decision then whether to build or use the mbp. One thing he also said, was that there is a way to increase the graphics capability setting, which is by default set lower to conserve power and speed for everything else, when you want to do heavier gaming.
