Trailex question
Trailex question
I have an open Trailex that I bought used. The axles are positioned for an early 911. I tow a 944. I wonder how difficult would it be to reposition the axles. Does anyone have an experience with this?
TIA
TIA
Will, at Precision Motorsports in Califon, NJ, is a Trailex Dealer and should be able to help you get this done. 908-832-6572.
Did it myself in about an hour. You just loosen the bolts attaching it to the frame rails and it slides in a track. Mine had bolts in the underside of the frame rails to keep the carriage from sliding out of position. Move them to your desired location and that makes it easy to no go too far.
I attached the tie down straps from the back (or front) then one of the axles. Then I hopped up and down on the straps to pull the carriage back.
If the trailer is used the biggest problem you will have is it being all corroded up and not wanting to slide in the track. Be patient and try to break the grip of the corrosion.
Another great feature of the trailer is the ability to move the tire rack. I mounted mine lower in front of the car and my gas mileage improved substantially...
See: http://www.driversmeeting.com/pcarroll/albums/51/1831
I did the job over the weekend. It was far more involved than what Peter described. I'm guessing that mine is an earlier model. It took me about 8 hours, including a trip to the hardware store. Not particularly difficult, just time consuming. All holes aligned perfectly and that is a testiment to the excellent engineering. I wish the hardware that they used was of a bit higher quality. Had I been smarter I would have ordered new spring bushing from Trailex to go with the new hardware.
My trailer was still pretty new when I did it so it went smoothly. An older trailer would be corroded and would require a lot more effort to get the axle trucks to slide... Also I got some new shorter uprights plus extra T-bolts from Trailex.
I have an older trailex - and 2 winters ago I did that. I put the trailer up on jack stands and replaced all of the suspension bushings - while I was doing it, I moved the axles forward about 12 inches. It was a little time consuming, but not difficult at all (I actually found the brackets that held the fenders on had the most corrosion).
Addicted Specialist
Is that utility box a Trailex accessory? I couldn't find it on their website. Did you get it with the trailer or add it on? Thanks!
EDIT: Ugh ...nevermind...just found it
Edward
