MOTON CLUBSPORTS?
Just wondering who has used them and what your impressions have been? Easy to setup? The remotes have bump, but not rebound so any issues with that?
Anything to suggest that these require more servicing, or difficulty in setting up.
Whatever you'd like to say in general.
thanks
thanks
Basic Site Sponsor
Basic Site Sponsor
Best entry level remote reservoir shocks you can get IMHO. Compression is on the canister, rebound is at the top of the shock rod. They seem to last a long time before servicing too. As far as setup goes, adjusting shocks is a learned art. Some can learn how to do it, more cannot. There are guidelines, but to get it right you need to be very sensitive to what the car is doing.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
thanks
thanks
easy to adjust, yes but easy to set up.....all depends on you. you'll need to know what to tune into/out of your ride and how to tune it. setups are closely guarded.
how easily you notice any change will depend on your ***. for me it takes 2 clicks at a time to notice a change. test test test. start at one extreme, like maximum compression, minimum rebound dampening then go from there. change one thing at a time or else you will be chasing your tail.
i haven't serviced mine since buying them used, ~3 years ago.
huh? your clubsports are not double adjustable? never heard of that before. mine have compression and rebound just as how larry describes it.
rebound being at the top of the shock is access, but we're thinking we might be able to cut a hole in the bodywork to get to this.
That's good advice re the testing to extremes as well.
These struts are Duo, not Monotube yes?
Ok, sounds good Larry. Yep the setting up of any shock is something one needs to apply time and money to.
No, what I meant was that the remote only covers bump. The problem with
I've been happy with mine. I wouldn't fret the tuning, you'll pretty easily find the ballpark. Determining between better and best is the tricky part.
Yeah I would think the inverted monotube design would allow for bottom adjustment as it being at the top would be a huge PITB!!!!!!!!! Even the cheap coilovers have that, wouldn't expect less from Moton. All you do is lay down and turn CW or CCW.
Oh, OK, that's good news. I should have remembered to ask you directly Eric. My KWs have the shock mounted in an upright (top to bottom) position so that means that you can't get to the rebound without dropping the shocks out. Not something you can really do so easily as opposed to mounting them inverted. So this is 100% the case with the Motons that the rebound adj **** is accessed at the lower side? Cool.
+1 on mine as well. They came with the car, and I set to the basic range Moton suggested. I couldn't be happier with them.
Confirming VR's comments, mine too rarely if ever have needed nitrogen replenished.
Team Owner
I will add to the endorsements. And I give many thanks to Larry Herman, who helped me understand what subtle things to look for in car behavior to see whether the adjustments I make are for the bettter or worse.
These things are awesome, and so is the car, now that I have it all figured out. I check N pressures before each event, but have had to add N only twice in over 2 years.
Professional Racing and Driving Coach
They do need to be rebuilt more frequently than most do. The recommended rebuild is about 30 hours. I can tell you that at 100 hours the shock oil is toast, the shim stack has weakened, and the o-rings may begin to leak internally, espeically between the nitrogen part and the shock oil.
Dumb noob question. My tech is about to install my set of Clubsports and I'm wondering, since my set came in a box with the cannisters disconnected from the shocks, do the larger cannisters go with the front shocks or rear shocks? Thanks.
Can someone illuminate me on how you adj the rear rebound? From what I see the rears are setup inverted but I can't figure out from the pics how you adj them even though you can clearly see an arrow.
