CV axle problem?
CV axle problem?
Appreciate input on this problem. Cross post from 993 forum but second thought might be better here.
Thanks!
https://rennlist.com/forums/993-foru...e-problem.html
Thanks!
hi.
on my FWD race cars, i need to vent the CV boots; otherwise, the heat will cause them to expand, and balloon out, and cause a variety of problems.
the quick down and dirty fix is to cut the band on the small end of the CV boot; then take a WD-40 plastic straw, and cut it in half. slide the straw in between the axle shaft and the boot, so that the hot gasses have a path to escape through the straw. re-band the boot lightly, so that you don't crush the straw. (do both boots on each shaft).
i now do this on all my FWD driveshafts, and have not had problems since.
good luck!
todd
ReidSpeed
PS if you repack the joints, use a good high quality synth CV grease. its a yucky job!!!!
good luck!
todd
ReidSpeed
Here's a site to get Neo from, may be cheaper elsewhere... http://www.hrpworld.com/index.cfm?fo...action=product
Thanks for the info and links. Kinda what I suspected. I will pull them off, inspect and repack or replace as needed. From now on will repack the new ones also. Do any of you follow a regular "repack" schedule for the track car?
Once per year and I have always used Swepco Moly Grease. I buy a tube, push all the grease out on a piece of cardboard, divide it into four segments and each CV gets 1 segment pushed in (after cleaning out the old grease as much as possible).. New gaskets and bolts also..
Interesting as I've blown another boot on my 930 last weekend. I always use a ziptie on the small end, but I guess it's too tight or the grease that comes with the kit isn't up to par.
I'm on a schedule of about every 25 hours to R&R (including when new). Due to my axle geometry and the heat generated the stock grease can last as little as 4-5 hours before the grease and CV start to fail. I (meaning the shop) now use Krytox and some adjustment to axle geometry were made and they are lasting much better. I still keep two spare axles in the trailer though.
- grab a squirt tube from a can of WD40 or similar, and cut a 2" section
- place the tube under the small end of the boot, then ziptie everythign in place
The tube acts as a breather. It doesn't vent grease, but it does vent air as the grease gets hot. Works like a charm.
I'm going to try that. The kits are cheap, but the grease and clean up makes for a nasty job.
Next time, try this:
Does anyone have a better way to clean the wheel side?
Not sure on other axles, but the 964/993 already vent via the center opening of the hub end. I just had to do my half shafts and went the extra step to completely remove the grease from the stub end which cannot come apart. You can run a degreaser through the center of the shaft and close the trans end of the shaft. What a PITA to get it all out and start new.
Since I have not yet pulled and looked closely at the assembly I'm not sure of what you mean by the "crimp" ? NEO on order. That Krytox is too near the price of new axles!! lol
