Project - trailer ramps
Created a set of trailer ramp extensions for the trailer (car would just hit on the way in)
Picked up a 4x10 1/8in aluminum diamond plate off of craigslist, took it to a local custom welding shop to cut and bend.
Mounted them up tonight and realized after I was done that what do people do to secure the ramps to the back door?
Don't want to stop quickly and have them hit the car.
Also need to tighten the torsion bar for the increased weight.
![](http://www.masondot.com/images/IMG_0122.JPG)
![](http://www.masondot.com/images/IMG_0123.JPG)
![](http://www.masondot.com/images/IMG_0124.JPG)
Phil
Phil
Looks awesome! Great project! Are the hinges bolted through? I'd think you'd need to go through and have a 1/8" or so steel plate, maybe 10-12" or so high, to go across the outside. You might even want a plate like that on the inside. As close as the hinge is to the edge of the wood I'd be worried it might pull through. (2 cent advice only worth that much)
They are bolted through on the aluminum plate, but on the door they are screwed into the plywood, but they could be going into the steel frame of the door.
I also put on three of these bumpers to raise the door itself.
![](http://www.northerntool.com/images/product/images/33185_lg.gif)
So when its open there really isn't any stress on the hinge itself.
My concern is them swinging when the door is up and hitting the car, may just use bungee cords or something until I figure a good latching system.
Maybe put one of those same bumper things on the ceiling, on each side, right at the door threshold. So when the door is up, the hinge is basically pinned against them and won't move.
Trying to think of something that is up and out of the way when the door is open. Any kind of latch that would pin them to the door is something I would be afraid to run or trip over.
Super Moderator
Needs More Cowbell
Needs More Cowbell
A simple meathod a buddy uses is to mount a d-ring on each side of the door and run a small ratchet strap over the ramps which keeps all snug to the lift-gate.
Thanks for the ideas, agreed I want it out of the way as possible, most likely it will be something on the edges, but I will look at the top too.
Time to wonder around in the hardware store.
the easiest for me are the orange traffic bollards I carry in the trailer: load the bike, load the car, put the bollards in and shut the door. The bollards are heavy duty plastic and serve as a bumper. At the track reverse the process
