HANS device wihtout Harness???
I hope this doesn't sound like a completely idiotic question.... but: What are everyone's thoughts on using a HANS device (not necessarily that brand, but a head and neck restraint device of some make in general) in a car without a harness. Is a harness necessary to use one effectively?
Having started instructing recently, and pushing myself and my car on track more and more lately, I have been seriously considering safety over other modifications.
As someone sitting in others' cars on the track and not knowing what their level of skill or comfort with high speed track driving is, aside from whether the car is truly prepped for the abuse, I would be lying to say I wasn't worried a little bit about all the possibilities.
So in this case, or even the case that your own car doesn't have a harness and you use the stock 3 point belts, would/do you recommend a HANS device at all. If not, why not?
Super Moderator
Needs More Cowbell
Needs More Cowbell
HANS without a 5/6/7 point harness: Not Allowed.
If you have a 3 point (instructing), the R3 device has been discussed here. It is worn, independent of the belts.
If you have any problems finding info on these devices via Search (it is still being worked on unfortunatley), please post or PM me and I'll find the info for you.
I did do a search but didn't come up with what I was looking for unfortunately. So thanks for pointing me toward the R3, I am reading away on that now.
Super Moderator
Needs More Cowbell
Needs More Cowbell
No, there will be no flaming.
It is a serious question and there is a tremendous amount of relevant information available in this forum to help him come to an informed decision.
Super Moderator
Needs More Cowbell
Needs More Cowbell
We have several members who regularly drive with the R3 device (which is SFI38.1 approved)
I use an R3 for the reasons you stated (sitting in a student's car with a 3 point belt). I like it and find it reasonably comfortable, but have not tested it in a crash (fortunately!). I know there are people on this board who question its effectiveness, however.
Are you sure?
Below is a direct quote from the HANS device website. Look under FAQ.
"Anecdotal reports indicate the HANS Device offers benefits even when worn under a 3-point OEM style of seatbelt. The user must also be wearing a helmet with HANS Device anchors on it."
A HANS with a 3-point OEM style seems like it wouldn't really do much. I could see some benefit it it was a 3-point with two shoulder straps (ie like a 5-point without the lap belts), but OEM style doesn't give me a good feeling at all.
I for one wouldn't wear a HANS with a 3pt. It may work, but is it worth your neck? I for one who has wrecked with a HANS and harness can say it works, in fact saved my life.
**** happens on a race track that are beyond your control, oil, coolant spills, jackasses that drop two wheels and try to get back on track etc. I personally owe it to my family to keep myself safe.
Another issue to consider, is that a car without harnesses will probably not have it's airbags disabled. How does that affect the hans' function?
Lastly, the OP wrote that he is starting to instruct, thank you first of all because we can't have too many instructors, but a pearl of wisdom that i was told when I first started and my student was above his head. "as an instructor with a rookie student you have to establish that you are in control of the car and set the expecation that he will follow your directions or he's going back in the pits.
I've used the R3 for a few years and though I was fortunate enough not to test it in an accident, I was pleased with its comfort, ease of use, and the ability to wear in cars with standard 3 pt belts (such as when instructing) or with 5/6 pt harnesses.
There are several drag racers that have had pretty horrific accidents while wearing the R3 and praise its abilities. No affiliation other than satisfied customer:
Link: http://www.safetysolutionsracing.com...p=585#more-585
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Super Moderator
Needs More Cowbell
Needs More Cowbell
Please show me sled test data, not anecdotal information.
Please show me in the official HANS owner's documentation the part where it shows belt geometries with a 3 point harness.
