How do I convert Minutes to tenths of a degree?
1 Post
I just had a revelation about my alignment. I am using SMART strings to align my car and the chart documents 10ths of a degree while Porsche uses minutes.
Factory GT3 rear toe is 0 degrees 10 minutes + 5 minutes/-0 minutes (per side). I need to convert this into 10ths of a degree to use the SMART strings chart. I'm no math wiz but here it goes:
60 minutes in 1 degree so 10/60 = .1667
+5 minutes would be 15/60 or .25
So rear toe in would be .1667 to .25. Using the SMART strings chart and a measured wheel diameter of 19" I should be 3/64ths to 6/64ths of an inch. Right?
Basic Site Sponsor
Basic Site Sponsor
Sounds right to me. I used to setup my GT3 with 3/32s toe-in on each side. Was very stable & didn't chew up the rear tires.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
1 Post
Interesting, that would be the factory maximum but my gut says that's where I need to be at. I'm at 3/64ths and it's not right. I think I have too little toe and when it squats under acceleration I go to toe out.
Still plays with cars.
Too little rear toe will also make the car wag its tail under hard braking.
For a second I though I was posting over on the long range shooting boards... (Minutes or MOA are what we use to factor wind/elevation, etc.) Looks correct to me, although I'm used to going from Minutes to Mils and vice versa.
Super Moderator
Needs More Cowbell
Needs More Cowbell
Download Convert.exe (yes, it's safe for downloading).
Very handy utility to have on your PC.
http://wscope.com/convert.htm
The Penguin King
Bill you better check your units and see if you are supposed to be using metric degrees or not.
on a 19" diameter, you can take the inches off parallel, and divide by the 19" diameter. just use a calculator and take that number and hit the INV TAN function. .5" is about 1.5degrees as you might find by looking at camber.
1/8" on toe, .125/19" Then use INV TAN, you will get .37 degrees or 22mins
1 Post
Mark, thanks for the info. My brain hurt after reading that. Two glasses of Scotch and now I feel mutch butter. Camp't understnf whatcha' talkin bout.
Basic Site Sponsor
Basic Site Sponsor
Funny you mention that. I have a whole bunch of 7 brackets too, but when I put them in a box and shake it really hard, sometimes a few change into L brackets! Try it and see if it works for you.
