Stiff springs - more or less grip?
Old 02-19-2009, 03:39 PM
  #46
Jarez Mifkin
Jarez Mifkin's Avatar
Originally Posted by mark kibort
One thing I stubbled across was that a soft suspension seems to work better for most tracks. I think the WCGT guys have all drifted toward softer suspension for more compliance over the years.
mk
Is that due to the chitty tires they run?
Old 02-19-2009, 04:46 PM
  #47
ervtx
ervtx's Avatar
Originally Posted by Sean F
what is a spring?
+1. For that matter....
what is a grouping?
is stubbling difficult?
where can I get some anti-squat, and
how does one avoid the strong couple?
Pardon my n00bness, but I am new to these terms
Originally Posted by wanna911
how much can different tires in the same grouping (slicks) or changing to a dramatically different grouping change your suspension settings?
Originally Posted by 2BWise
Dive and squat can have dramatic effects and without much anti - dive/squat designed in the easiest way to counter act that is with stiffer ride springs.
Another large drawback of large bars is that you've now put a strong couple between opposite sides of the car which will have drastic events in one wheel bump.
Old 02-19-2009, 04:49 PM
  #48
Veloce Raptor
Veloce Raptor's Avatar
Received 1,494 Likes on 791 Posts
what is a grouping?
Son of a....
Did Dr. Pain steal your user ID?
Old 02-19-2009, 05:03 PM
  #49
ervtx
ervtx's Avatar
speaking of stiff springs and suspension geometry.....
Old 02-19-2009, 05:05 PM
  #50
Veloce Raptor
Ahem:
Old 02-19-2009, 05:12 PM
  #51
ervtx
ervtx's Avatar
Sorry, I forgot to mention "body roll" and supple.
Old 02-19-2009, 05:16 PM
  #52
2BWise
2BWise's Avatar
Built for speed or comfort?
Old 02-19-2009, 05:26 PM
  #53
Veloce Raptor
yes
Old 02-19-2009, 05:47 PM
  #54
tomburdge
tomburdge's Avatar
Originally Posted by stownsen914
Tom,
Yes, it's a six, but only a 2.7L. I used to run 300 in front and 175 rear in my 914 (at Doug's suggestion, by the way), and was always happy with that setup. I went heavier recently because I'm doing some experiments with underbody aero. From all the reading I've done it's important to keep the ride height as constant as reasonably possible when running a diffuser. Instead of going rock solid, I compromised and went somewhat stiffer.
Scott
Given the parameters of production racing in SCCA I don't think my car would be driveable with your spring rates.We are very limited on just about everything which is why I am at such a disadvantage in PCA racing.
.Since SCCA won't allow us any rear spoiler in production classes,a defuser in my case would create an imbalance with too much down force in the front and nothing in the rear.
So,good luck with your defuser experiment.
If you race in PCA,perhaps someday we will share the track together.I only do one or two PCA races a year.The rest are dedicated to SCCA.
Regards,
Tom B.
BTW , in what venue do you race the car.?Sounds like a GT4 or 5 car in PCA.
Old 02-19-2009, 05:59 PM
  #55
mark kibort
mark kibort's Avatar
You will have to remove the fender covers to see the springs and judge their compliance and dynamic action in real racing conditions.
Originally Posted by Veloce Raptor
Ahem:
Old 02-19-2009, 06:01 PM
  #56
mark kibort
I think that was with the Chitty tires they USED to run. (i.e. 280 tread wear )
Old 02-20-2009, 12:58 AM
  #57
justaguy
justaguy's Avatar
On the track With the original stock springs my 87 S4 is constataly banging off the stops violently enough that I am afraid I might damage or even break something in the suspension.
If the suspension is continually bottoming out dosn't that mean the springs are too light? I have purchased a set of 600-400 hypercoils which I intend to install before the season starts. Any body else running those spring rates on a stock 928? How did the stiffer spring affect the handling?
Old 02-20-2009, 01:23 AM
  #58
Rich Sandor
Rich Sandor's Avatar
Sometimes I wonder what it would be like to race a car with no suspension - basically a car-sized go-kart.
Old 02-20-2009, 01:35 AM
  #59
mark kibort
Im on the very soft side at 750 and 475. anything less and at a greater weight will be a sloppy mess on the track. If its a street car and used for track use, it will be very nice though. For racing, I think it would be a little too soft.
mk
Old 02-20-2009, 01:56 AM
  #60
justaguy
justaguy's Avatar
Street car 10 track days a year
Thanks for the coment
Quick Reply: Stiff springs - more or less grip?
