Stiff springs - more or less grip?
Basic Site Sponsor
Basic Site Sponsor
Seeing as how Kibort got everyone torqued out of shape on the HP thread, I figured it was my turn to start up a suspension squabble.
The basic premise is simple - Do stiffer springs offer more grip, less grip, or both, depending on the circumstances?
My feeling is that on smoother surfaces, stiffer springs offer more grip because the car leans less and the tire contact patch stays at a more optimal shape. On a rougher track, grip suffers because the stiffer springs load and unload more quickly, causing a larger variation in grip than with softer springs that track better. All this assumes that your shock settings are optimized for the conditions.
Your well-thought out opinions and experiences are appreciated. Knee-jerk reactions and regurgitation of dogma will be dealt with Rennlist style.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
In general, I think you can say the smoother the track, the more good a stiff suspension will do you. Here is the Northeast, where smooth tracks are few and far between, you'll get lots of opinions on whether stiff is better or worse. I can think of several quite successful SCCA and PCA racers who liked very light springs on their (fast) 914 racers. Like 300 lb/inch or less. Their cars are of course comparatively light. Some people prefer much stiffer, even on bumpy tracks. Personally I tend toward the lighter end of the spectrum with 500 lb/in on the front of my 914 race car and 350 on the rear. You can of course run stiffer sway bars to avoid lean in turns even with a lighter sprung suspension.
Scott
Scott
Perfect timing, I was going to start a thread like this one myself.
My common sense, which may not be applicable, tells me that stiffer springs should allow a larger opportunity for using less damping (bump). If they can control the body roll some, you can go some clicks softer which on a 2-way adjustable suspension should be very helpful since you don't have high and low speed bump controls. Using more spring to keep the car stable and planted, but less bump to handle bumps and curbs.
THIS IS A GUESS.
THIS IS A GUESS.
Team Owner
I agree with this totally. More suppleness is better on rougher surfaces.
Basic Site Sponsor
Basic Site Sponsor
Yep, except for some of the stuff Chris Walrod & Geoffrey come up with. But some guesses have a lot of experience and testing behind them, and some are just pure speculation disguised as "opinion".
Are we a little testy today?
Scott,
Holly cow! 500# springs on a 914.
I run 350# front and 200# rear in my 1.8 ltr (4cyl) and turn 1:01's @ Lime Rock prior to recent re-pave.Doug Arneo put this package together for me years ago and I think it works pretty good.Also run front and rear sways but not real big ones.To me the car feels like its on rails with no white knuckle sensations.
You must be running a big six cyl.
Tom B.
Tom B.
I don't have the seat time in to notice the difference, but every suspension book I've read says, most people have a misconception about springs. They think that the car's reaction (bounce) is based on what the contact patch surface of the tires are and the spring's stiffness. However the car is typically heavier, and therefore the wheel's reaction (bounce) is based on the car's weight and the stiffness of the spring. That is basically the Car is usually the heavier object and therefore pushes the wheels down back to the road faster or slower based on your spring rates. This also leaves the argument of which feels better open due to your ratio of sprung (weight supported by springs) and unsprung wieght (weight not supported by the springs), which affects the feel of the spring rate....
Depends;
It's like tire pressures. The graph is a pyramid, the peak being optimal. If you are undersrprung for the weight of the car and the grip of the tires, then obviously stiffer springs will increase grip (and braking performance too) by "pushing back against the chassis" and planting the tires into the pavement harder. If you are already at the limit of weight:spring rate: tire grip, then stiffer springs will decrease grip.
Then of course there is track surface. Smooth tracks will handle more rate, while rough tracks reward a more resilient ride.
Then there is aero. More aero squats a car more, and may require increased rates to simply keep the chassis from bottoming and reducing grip. INDY cars don't need 1500lb springs based on a weight of about the same, but they do because of the aero effect they generate. It is the downforce that makes the cars "heavy."
All of this is open to revision based on actual circumstances.
Basic Site Sponsor
Basic Site Sponsor
Definitely Maybe.
This question is identical to: "is more air pressure better in tires?" The answer is the same: "yes, to a point. After that point, no." For a given situation, there's generally an optimum.
Larry, with all due respect, I think you should have asked: "How do I determine if I need stiffer springs?" People could squabble forever over the practical meaning of "grip".
