cordless inpact gun what to buy
Old 02-15-2009, 11:32 PM
  #31
rabjohns
rabjohns's Avatar
Goodyear junk, DeWalt +1
Old 02-15-2009, 11:36 PM
  #32
ngoldrich
ngoldrich's Avatar
My 1/2" snapon does not work as well as my 1/2" Dewalt which is why I purchased the Dewalt.
Norm
Old 02-16-2009, 12:18 AM
  #33
NJcroc
NJcroc's Avatar
I love my Ingersoll-Rand W360, It is amazing and never quits
  #34
lawjdc
lawjdc's Avatar
Originally Posted by Arkadi
Milwaukee has been bullet proof.
You will not find a more powerful cordless impact wrench than the 1/2" 28 volt Milwaukee. Period. You owe it to yourself to take a look and compare. It comes in a case with 2 batteries and a quick charger.
Old 02-16-2009, 10:50 AM
  #35
Bryan Watts
Bryan Watts's Avatar
http://www.motherofallcordlessimpactwrenches.com/
The Milwaukee lists it's max torque at 325 ft. pounds. The Snap-On lists a max torque of of 620 ft. pounds.
Old 02-16-2009, 12:46 PM
  #36
DogInBlack
DogInBlack's Avatar
Just a friendly reminder- Check final lug torque manually. Don't rely soley on your gun settings.
Old 02-16-2009, 01:03 PM
  #37
Larry Herman
Basic Site Sponsor
Larry Herman's Avatar
If it doesn't have enough torque to do this,
It ain't worth squat!
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Old 02-16-2009, 01:08 PM
  #38
Veloce Raptor
Veloce Raptor's Avatar
Received 1,607 Likes on 836 Posts
Werd. Although REAL men have 5 lug hubs.
And I told you torque was king!
Old 02-16-2009, 01:42 PM
  #39
Rassel
Rassel's Avatar
+1,
Also, the light function that some have can be handy.
Old 02-16-2009, 02:05 PM
  #40
dmwhite
dmwhite's Avatar
Originally Posted by sjanes
I use the DeWalt DW059.
i've been using one since early 2005...it gets used a LOT and has worked great for me...the only issue i've had was one of the batteries dying last year...
Old 02-17-2009, 09:49 AM
  #41
kurt M
Mr. Excitement
kurt M's Avatar
Originally Posted by ervtx
+1 Professional grade drills and impact guns.
FWIW, Dewalt is manufactured by Black and Decker; more of a high-end consumer brand compared to Milwaukee.
Other considerations:
Lithium batteries hold a charge longer than NiMH and can be trickle charged w/o reducing battery life.
More power = more weight.
DeWalt is owned by B&D the tools are made by many companys. My DeWalt 3 hp router is made by Elu for example just like Snap-On.
Originally Posted by Steve Weiner-Rennsport Systems
Snap-On or Ingersoll-Rand W360 w/lithium ion battery
Originally Posted by APKhaos
^^ +1 on the Ingersoll-Rand W360
+1 on the IR. I have the Snap on and when it wanders off or breaks I am getting the IR. Nice gun, nice trigger and feel. Good price on the gun and batteries from a well known national company. Whats not to like?
The DeWalt and Milwaukee and any other non VSR gun have a real problem in being on/off only IMO. Without variable speed the tool is limited to knuckle dragging lug bolt work only and even in this task also risks cross threading. With a VSR gun you can start off nice and easy running the nut down the stud and not ding the threads if you feel the nut bind. I use my Snappy for all kinds of work from knocking lug nuts loose to resetting plastic 10mm undertray nuts. It has stood up to all kinds of unreasonable tasks and abuse levels normaly reserved for ex wives for many years so far.
Look at the weight of the tool the Mill is 10 pounds and large in frame.
As to reasonable batteries for the Snap-On. You will not find them on the Strap-On truck as they are $150 or so. You can rebuild them yourself or send them out to a battery shop. Google replacement rechargeable battery packs and you will find plenty of shops. You can also get a battery pack of the same voltage from Home Depot open it up and solder the battery cluster into your Snap-On pack. I got a set of two 18V packs for $45 on sale a while back.
LI batteries last for about twice as many charges but cost twice as much and so far don’t have cheap rebuilds. The older batteries will last longer if you do not fully discharge them. When you feel the power drop off, recharge. They are not like the first gen rechargeables and do not take a memory. Most can be left in modern name brand chargers without any issues. I have some non LI that are 3 or 4 years old and countless charge cycles and just swap them out as I use them. The key is recharging when the power drops off not when dead.
Old 02-17-2009, 03:09 PM
  #42
mrbill_fl
mrbill_fl's Avatar
Originally Posted by mglobe
Actually, I've been using a Goodyear model for about 1 1/2 years now. I've used better ones, but I only paid about $80 for it from Pep Boys. It works just fine. When it breaks I'll throw it out and probably buy another just like it.
goodyear is marginal for me... it will not break free my nuts! ha!
I'm torquing to 90#, and need to use the breaker bar on each nut... its quick but only does part of the job...
Old 02-17-2009, 03:12 PM
  #43
techno99
techno99's Avatar
I stopped having a problem once I stopped using a 3/8" socket with adapter. Once I started using a 1/2" socket, I haven't had any trouble unless my battery is almost dead.
Old 02-17-2009, 03:32 PM
  #44
Seth Thomas
Seth Thomas's Avatar
Originally Posted by dmwhite
i've been using Strap Ons since early 2005...it gets used a LOT and has worked great for me...
Corrected for you.
Back the question, I have a Snap On from 2001 that has been working flawlessly since then. The only issue has been replacing batteries
Old 02-17-2009, 03:39 PM
  #45
Geoffrey
Geoffrey's Avatar
The Snap On unit will work with centerlocking nuts and mine has been fine for 4 years.
Quick Reply: cordless inpact gun what to buy
