Which Splitter for a 99 c2 with a cup wing?
Old 02-13-2009, 04:50 PM
LVDell
LVDell's Avatar
Originally Posted by JC3D
Thank you dell. That is the answer I was looking for. Is it just the regular mk2 splitter? or cup? Right now I have the lower portion that is supposed to be on the mk1 bumper.
I did that 1:32.1 earlier on in the day, but tires started going away on me later in the day.
The MkII cup splitter is the one you want. There are basically 3 OEM options for you....the MkI splitter, the MkII splitter, and the MkII cup splitter.
The best of the bunch is the MkII cup splitter. It's a little deeper and a little wider. Also more sturdy. I have the MkII splitter on my CAB and the MkII cup splitter on my GT3.
Here is the thread I did over on Renntech that shows how I got a MkII splitter on a MkI bumper:
http://www.renntech.org/forums/index.php?showtopic=4095
Also, here is a picture showing the difference between the Mk II spliiter and MkII cup splitter;
https://rennlist.com/forums/996-gt2-...k-spliter.html
Old 02-13-2009, 04:53 PM
LVDell
LVDell's Avatar
Originally Posted by AudiOn19s
What's your ride height? Dell's onto something there with the rake comments. Tough to tell from the picture as you could very well be hard on the gas but it looks like the front isn't low enough / rake isn't right. You should have around 15mm rake in the car.
My rake delta was about 10mm but then again I had a VERY low ride height.
Old 02-13-2009, 04:54 PM
JimB
JimB's Avatar
You really want to use the later 996 cup splitter. You will need to drill a couple of holes but it's an easy install. If you need the part number I can get it to you when I get home and check the manual.
I think the guys are right about the ride height and rake but I'm not sure that's going to solve your problem in a high speed corner. Assuming they make you run pretty soft springs that wing it going to compress the back and and naturally lift the front. It doesn't take much at 135. I remember just adding a wickerbill to my old 996 cup's wing caused me to go from neutral to a push so bad I almost drove off the track.
With only 300 hp I wonder if that big wing will do more harm than good?
Old 02-13-2009, 05:08 PM
LVDell
LVDell's Avatar
MkII Splitter
996 505 986 92 01C
MkII Cup Splitter
996 505 986 91
Old 02-13-2009, 05:35 PM
JC3D
JC3D's Avatar
Thanks Dell, by any chance would you know the difference in price between the 2?
Old 02-13-2009, 05:36 PM
LVDell
LVDell's Avatar
The MkI splitter is less than $100
The MkII splitter is about $250
The MkII Cup splitter is about $175 (go figure right, something cheaper by PMNA over PCNA!)
Old 02-14-2009, 11:09 PM
trackjunky
trackjunky's Avatar
I fully expected that big wing to cause a balance problem. It's way too much downforce, especially for a car with less than 250rwhp. The Gt3 RS wing might have been a better choice. A Taco Winged car will be faster in a straight line than one (996 Spec) with a Cup Wing.
My guess is that it may also cause intake issues if not used with the proper decklid.
Quick Reply: Which Splitter for a 99 c2 with a cup wing?
