Aiptek + Filmtools Cleat mount
Some video footage from a wet track this weekend using the above setup: http://www.youtube.com/watch?v=z5mr1nY_OJE
Not bad for a camera setup that costs $275 total.
Hi Paul,
I've placed the camera in two positions so far, up front under the rearview mirror and on the rear window near the headliner. The mount has enough adjustment that you could probably mount it right side up, but I find it easier to mount it upside down and then flip it using software. The major problem is the wind. Not only does it drown out the sound if you mount it in the rear, but it also makes the camera vibrate.
Here are some vids from yesterday that demonstrate the two positions and the effect of wind at high speeds:
Windshield cam: http://www.youtube.com/watch?v=xbOlqL0rshA&fmt=6
Cockpit cam: http://www.youtube.com/watch?v=50x1Fx2xP0U&fmt=6
DVD quality versions of half-sessions:
http://www.fcracer.com/gt3/mosport-s...ion-3-half.mov (600mb)
http://www.fcracer.com/gt3/mosport-s...ion-4-half.mov (300mb)
FC,
I see what you mean about how placing the camera in the back window introduces a vibration. I have a bit of the vibration as well. I am using a suction mount from panavise that I borrowed from a buddy to try out.
I plan to look around under the back shelf area for any suitable areas to secure a mount directly to some sheet metal.
I am looking at the cleat mount for an Aiptek camera, and I'm wondering about the range of adjustment on the articulated portion, as well as the rigidity. filmtools.com has a video on their site where the mount was used on the underside of a boat, which seems impressive -- maybe the rigidity is a no-brainer.
WRT the articulation, it looks to me as if the main swivel can move 360° and each of the two remaining joints can move > 180°. True? This is important to me as I want to mount the camera to the inside of my rear window and I want it to be as high as possible so I can see the road in front of the car. The higher-end units like this one will fix the camera at a certain height, giving me no options in that regard.
The Penguin King
Before I had a cage, I used The Gripper http://www.filmtools.com/gripper-302...era-mount.html which is a larger version of the cleat. It has more adjustability, and allows you to mount the camera on the back window with it right-side-up. It is very sturdy, and you really don't much camera bounce.
Here is some video I shot with my Aiptek A-hd and using The Gripper mounted to the rear window.
http://www.vimeo.com/1261038
You can improve the sound a little bit by taking the cover off the microphone, putting a piece of felt over the mic, and then putting the cover back on. It just slides off. It also helps to put some masking tape over the microphone cover.
For the cockpit cam, it's odd that it can't see over the dash. Is it all the way up? \Needs to be about 4 inches higher.
Quality looks pretty good, and not too "jiggly".
My camera has a mic jack so I was thinking of taping one of these inside my bumper cover above the exhaust tips.
Give him a break, someone stole his engine and shortened his hood -- that's why the hood isn't visible in the vid.
...My camera has a mic jack so I was thinking of taping one of these inside my bumper cover above the exhaust tips.
Here is an Aiptek shot at lowest res, mounted on an ioport mount on my roll bar. Since then, I've put o a wide angle lens, and it is enough to see the entire windshield and my dash.
http://www.veoh.com/videos/v15788802za6MAGJw
I called filmtools.com earlier today, they say the pad is 6-1/8" in diameter when attached, so it will fit. I ought to have that and the mic by mid-week, will be building a "frankencharger" soon. Thanks again for the heads-up on the mount Mike, I'll post a video when I have one.
Well, I bought the gripper 3025 and it didn't allow me to mount the camera right side up, at least not with the cup mounted near the top of the glass, clear of the defroster element. I gues my rear window is too close to horizontal for that. I took the articulated arm off my trekker and between the two I was able to position the camera where it could see forward, but there was a LOT of shake(because of the cantilever effect o the two articulated sections, I suppose).
I took the cup off of the arm and attached a tripod quick-release to the 3/8" threads with a couple of washers. Amazingly enough, the camera is in a perfect position now, though upside down. Easy enough to flip the video later though. I'll get some footage on YouTube and post it later.
The microphone that I linked above is not working with the Aiptek GVS cam, though it works fine with my laptop. When I look inside the mic jack, there are several contacts in there so maybe I just need an adapter.
The Penguin King
Sorry to hear that didn't work out better. I don't think I ever worried about the defroster element. I just suctioned the thing to the rear window and drove. You might try that. The thing holds VERY tightly.
Putting it lower on the window puts it much further to the rear, to the point that I get a narrow view between the front seats. Mounting straight to the cup seems to put the cam in the perfect position, and is rock-solid. I'm going to experiment a bit more around town. I can always use the articulated arm for something -- I'm a bit of a shutterbug.
BTW, I talked to support and the Aiptek GVS wants a stereo mic -- I'm going to try to find an adapter.
Well, I've posted a video of my camera mounting tests. I'm very happy with the initial results, and will straighten and firm up the mounting as well as explore microphone and power options. If you click the video after it starts to go to the YouTube page, there will be a link at the bottom right just below the vid to view it in HD.
Thanks Mike, for steering me toward the larger 6" cup. I'm sure it helped.
