Cup Tear Drop Mirror Replacement
That was a 1990 only option and I haven't found them, and Weissach was out of them when I purchased the rest of the spare parts for the 964 Cup several years ago.
Amondc,
I do have one on the other side. But how do you get it off. I have been looking and I can't find where to adjust the mirror, let alone take it off.
I have tried to move passenger mirror to adjust it and it won't budge. I am afraid that if I use brute force, I will be without this mirror as well. Any input will be appreciated.
the 996 cup mirrors had a nut on the inside. if you take the mirrior off the car is there a hole that allows you to get inside the housing? I have never taken one of those apart so I dont really know.
Man of many SIGs
Here is an aftermarket reproduction of the 935 mirror which looks the same as what you are showing.
http://vertexauto.com/ShowItem/17605...ror%20Set.aspx
Thanks for everyone's input.
I called Vertex who then recommended that I talk to Better Bodies of California. BB makes the fiting and the glass. http://www.betterbodiesmotorsport.com/mirrors.htm.
Apparently, the manufacturer of the glass w/the plastic backing plate went out of business 5 years ago.
Problem solved!
Problem solved!
Yes, I was there and I saw your car as well and said to myself, "i recognize that car from Rennlist." I just got that car and am still trying to sort it out.
Will the glass from a Vitaloni mirror work?
