Tire quiz
I have two pictures below. My left front and Rear.
The left front, you are looking at it as if you were standing at the front of the car looking back. You will note that the middle rib is warn down on the outside edge as if someone ground it off. this is a 235/35/19 Corsa from my GT3, they recommend 30 hot I run it about 33 hot. People have told me two different theories as to why the middle rib wear is uneven and taking off one side. Over inflation making the middle stick up more, but my question why is in not even across the rib, it just taking off one side of it.
Under inflation, the tire is bucketing or folding making the middle rib stick out and wear it down. It is only on the right front.
Second picture is one of my rear tires, both have just started to develop these crack in the middle tread, that is a first runs hot at about 34 to 35.
Whats your opinion on the front overinflated or Under on the front tire?
on the rear tire I am talking about the 3 splits just above the middle of the picture above the rain channel.
Perfect Angel
The middle rib wear looks pretty normal for a front tire on a tracked car. (assuming from your avatar) Do you have the factory alignment? It is set for mild understeer. High speed turns will cause that kind of wear particularly with a stock set up.
The cuts? I dunno. It may explode. Better just give me the car
It looks like you have Direzionales in front and Asimmetricos in back.
The wear pattern of the middle band of the front tire doesn't surprise me. MPSCs wear the same way... each band of the tire is more worn on the outside edge even with a proper track alignment.
You may be able to get better wear across the fronts with some alignment tweaks (the outside edge thin lines are disappearing in the front tire pic). With your current specs, you may not have much more room to play with pressures since you're already working the edge of the tire. Perhaps more neg camber will provide more even wear and allow you to drop the pressures a bit, too.
IIRC, the Corsas have rows of thin lines molded into them, and in the pic of the rear tire, the thin lines showing up in segments aren't in the original mold. That rear tire IMO will be prone to chunking soon.
You may want to contact Pirelli or your distributor to see if you can get the tires replaced on their dime.
Shave your tires.
The alignment is the track set up recommended in the manual toe 0 front camber -2.1 rear -2.5, I am just wondering if the middle rib is wearing on an angle why not more wear on the outer shoulder on the left front, I would think that it would be punished to. Maybe the camber is helping that. I have experimented with tire pressure more and less and can't seam to figure out what will help it.
The cuts? I dunno. It may explode. Better just give me the car![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Frank, is this wear from Mid-Ohio, or another track?
Frank
Next time you need an alignment, go to Bill Brauksick in Cincinnati. I think his shop is called Performance Alignment. Audi has flown him to LeMans. As far as I am concerned, he is the alignment/corner balance/ride height king.
My old tires had a similar tread design and always wore the center rib like yours tires did...even with adequate negative camber. (and even too much negative camber at times when I was on streets). I wouldn't worry about it.
I also can't believe those still have that much tread on them!
Andy
Andy
Looks like my RA1s after a few days at a right-turn track (Summit Point). Most of the tread blocks show a camber from the stressed edge rising up to the unstressed edge.
