View Poll Results: Would you build a 996 Spec if this became a PCA Class?
Absolutely! I'm in!
39
25.16%
Interested, but not right now
69
44.52%
No
47
30.32%
Voters: 155. You may not vote on this poll
Would you build a 996 Spec?
Old 07-14-2008, 02:46 PM
  #61
Paul 996
Paul 996's Avatar
Now there is an idea! And def allow the 3.6 cars.
Originally Posted by JimB
One idea for suspension might be to allow the Sachs dampers and factory spring rates that came on 996 cups (pick a year range).
Old 07-14-2008, 02:57 PM
  #62
Paul 996
Paul 996's Avatar
I for one am all for the biggest tires, especially up front. But for a spec class I would vote for a square setup front to back to allow for maximum tire swap and longevity.
I have been trying out a 275 R6 in the front and have been flat out amazed at the improvement. Just happened to have the 275s and the wheel to fit them on up front and thought I would try it... Amazing level of turn in and grip. And no the stock rear 18x10 ET65 won't fit unless you add a 20mm spacer. Unless someone knows different.
Old 07-14-2008, 04:03 PM
  #63
Ray S
Ironman 140.6
Ray S's Avatar
I'm not sure I would be in favor of a "square" set-up. But I would vote for one class Tire Brand/Model/Size to reduce expenses.
Old 07-14-2008, 07:44 PM
  #64
mglobe
The Penguin King
mglobe's Avatar
That seems to me to be an essential component, both in keeping a level playing field, and in keeping operating costs down. Probably Toyos, or maybe Goodrich?
Old 07-14-2008, 08:50 PM
  #65
Ray S
Ironman 140.6
Ray S's Avatar
I agree
Old 07-14-2008, 08:59 PM
  #66
trackjunky
trackjunky's Avatar
So I must admitt that I am somewhat confused.
Here's what I am hearing:
1) keep costs down
2) Add all sorts of mods to make the car faster, but see #1
3) Don't allow expensive shocks, but let's put a $2,000 wing on it.
4) Safety is important, but why do we need GT3 control arms?
5) Keep costs down for tires, but lets run the biggest most expensive tires we can find
6) Balance for these cars is critical, but Porsche screwed up when they went with 245's up front and 285's out back on the Cups
See my confusion. This is why rule making is so difficult.
The question should be, if you started with a stock car (not necessarily the car you currently own) what would be the best, safest and most cost efficient modifications you could make to it to turn it into a Spec Race car?
I'll direct everyone to the Koni rules for some insight.
Old 07-14-2008, 09:11 PM
  #67
DrJupeman
DrJupeman's Avatar
1) keep costs down
Agreed, folks have to look at the spec class not as a way to make the cars faster or look cooler, but be safe, reliable, and as cheap as the sport reasonably allows.
To that end, why a wing? Why big tires? Why crazy shocks?
It seems to me that you want to strip as much weight out as possible, put in safety gear, lockdown the engine and transmissions from tampering/adjustment, find a strut setup that allows for required track-tire camber, and pick a reasonably firm spring rate that will allow good drivers to have fun (if I'm remembering correctly, I think the spec Boxster rates sounded too soft). That's it.
Old 07-14-2008, 09:30 PM
  #68
mglobe
The Penguin King
mglobe's Avatar
We're aiming for a build cost of around $45K including car and your sweat equity, ...
This spec would be for 1998-2001 3.4 litre 996's.
... Boxster Spec > 996 Spec > PCA GTB > GT3 Cup
1) keep costs down
Bill
There have been lots of useful and interesting input and perspectives.
Maybe we need to go back to your opening post & look at what the objectives of the spec are. At the risk of putting words in your mouth, I'd propose that this is what you're after:
  1. Rear engine platform
  2. Relatively low entry price ~$45k
  3. Reasonable operating costs -- (mostly tires)
  4. Success differentiated by driving skill rather than depth of wallet
  5. Reliable
  6. Safe
  7. Greater performance than Boxster Spec
It's easy to get sucked into the "if we do this, it will be faster" frame of mind. If everyone were to be directed by a common set of objectives, it might help. We shouldn't be after creating the fastest 996 possible. Rather the one that meets the above goals best.
Old 07-14-2008, 10:04 PM
  #69
trackjunky
trackjunky's Avatar
We have a winner!
Jupe, my intent of the thread was, if you could build a car with these specs for this price would you be interested?
Now, trying not to interfere with the Boxster Spec class, while at the same time providing a next logical step in performance is a good thing. Simply changing to Double Adjustable shocks would differntiate the two classes from a tuning perspective. This is one step on the growth curve to learning how to race: car set up. Everything else should stay the way the Boxster Spec guys laid it out.
And yes, allowing a higher spring rate(s) is also a part of tuning and performance, but goes back to the shocks. Lock down everything else, and viola! you have a Spec class. Simple and easy. Hell, the Boxster Spec guys have already picked a tire supplier, so that's a done deal.
Old 07-14-2008, 10:08 PM
  #70
Veloce Raptor
Veloce Raptor's Avatar
Received 1,567 Likes on 822 Posts
gotta have a HUGE wing, Bill...you know that
Old 07-14-2008, 10:17 PM
  #71
trackjunky
trackjunky's Avatar
I gotch ya wing right here.
Old 07-14-2008, 10:19 PM
  #72
DrJupeman
DrJupeman's Avatar
We have a winner!
I voted, "would be interested, but not right now". I already run in a spec 911 class.
It is a hoot and I have no interest in moving on. At some point, if a 996-based class became popular, I could see trying it if I couldn't get into another spec 911 class (a la GT3 Cups). What would attract me is free availability of parts, "cheap" engines, lower tire running costs, etc.
Old 07-14-2008, 10:26 PM
  #73
amondc
amondc's Avatar
1) keep costs down
Bill
One easy way to control suspension is to limit ride height. It costs nothing but eliminates people going crazy. I would say yes to the GT3 arms, atleast in the front, Cup wing is more bling...., pick a standard size tire and manf., use stock wheels or if people want aftermarket they have to be same size and WEIGHT as stock. Keep LSD's factoy, they have put a lot of R&D into them and it will also control different ramps etc.
Chris
Old 07-14-2008, 10:27 PM
  #74
Veloce Raptor
Ha!
Old 07-14-2008, 11:14 PM
  #75
jrgordonsenior
jrgordonsenior's Avatar
Shock adjustability is overrated IMHO.... I would suggest choosing your spring rates first and then ask Bilstein to valve their fixed HD shock to match. This should save significant costs, assure a steady supply of shocks, and keep the playing field level. I wish they had done that with the Spec Boxster instead of the PSS9's which really need new valving and revised spring rates....
Quick Reply: Would you build a 996 Spec?
