Anyone race with eyeglasses
Super Moderator
Needs More Cowbell
Needs More Cowbell
Wondering if anyone who wears glasses has suggestions/ideas/types of frames, etc for keeping their glasses from 'falling off' while racing.
My son, who unfortunately inherited my eyesight, i.e. blind as a bat, is having some problems with his glasses falling/sliding under his helmet while karting...we couldn't figure out why he slowed down in the middle of a race and was trying to open his visor and drive with one hand....
FWIW, he is wearing an Arai GP5 with a balaclava and Nike Flexon frames that do not hook behind the ears, just go straight back, aviator style.
The current solution is to tape the glasses to the sides of the helmet padding on each side of the eyeport after he gets his helmet and glasses on, before he goes into parc ferme.....looks funny but it did work last time out.
Contacts are another option (although some people have commented on them sometimes popping out on bumpy tracks.
Someone else even mentioned that you can get an Arai visor made to match your eyeglass prescription.....had never heard of that and haven't been able to find out anything yet.
I had the same problem. I ended up getting a pair of WileyX SG1's made up which come with a strap that attaches to the frame when you remove the arms. No issues with comfort or fogging inside the helmet. Best of luck.
Regards,
Gregory
Regards,
Gregory
I wear glasses and have never had that issue. Suggest you go to a lenscrafter (or similar) and get the glasses adjusted so the dont slide around, as it sounds like they are way too loose.
NASA Racer
I wear a pair of Nike wrap around sunglasses that are very snug. I would suggest something similar. Because they are intended to be worn during sports, they wrap well behind the ears and are very tight and I don't get any slipping. I got the Nike because it was the most significant wrap around that you could still get a prescription lens in.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
LASIK docs don't like to touch eyes until mid twenties so they know that they've stopped changing.
I used to race with glasses. Now LASIK.
However I would do a couple of things. As someone mentioned, tape was useful.
Ones that hook around the ears were the best by far. I generally didn't have to tape those since they were held in place by the helmet. The tough part was finding a pair that stayed close to the face and then bent inward just a bit so the helmet didn't push them askew.
Karting may be a bit tougher since it is much bouncier. I'd recommend taking the helmet to the eyestore and testing that way.
I don't have the problem, but I would suggest going to an optician who specializes in glasses for extreme sports, etc. I have a Nephew who is an Optician and he carries a wide variety of unusual frames for prescription glasses, which are designed to stay in place under conditions that would be a problem with regular frames.
Lewis, I wear glasses and race. Ironically, I moved from contacts to glasses because my contacts would fall out while driving (I don't blink much at speed - seriously). It sounds like his glasses are too lose or his helmet is. Granted karting is a lot rougher than cars but I'd think between the glasses squeezing the head and the helmet squeezing the glasses, it'd be hard for the glasses to shift around.
I started wearing annetts, (sunglasses) wraparound style, and they didn't fit well once the helmet went on. (lifted)
swiched back to rayban predators (my old pair) and no problems... same as always...
-suggest, checking the frame w/ helmet fit.
Formula One Spin Doctor
uhh ohh,, Glasses in a kart ? go for the contacts his depth perception will be much better , lasik when he comes of age... a side note, lack of perfect natural vision will limit his abiltiy to climb the ladder , depth perception will become a problem as he climbs into faster machinery , move him to contacts this will improve his situation now ............
Agreed when he can .......................
I wear glasses. I have never had an issue using my regular glass or prescription sunglasses in 9 years of track driving. All my glasses go behind the ears like most glasses.
Of course driving a softish spung 944 may be helping
NASA Racer
