Info Needed on Building '00 Boxter into F-Stock
I was trying to find a car that's already built but there doesn't seem to be any. So the next option is to build one myself or really have someone do it and pay for the work. I would have to have at least the cage done by someone and the diff put in, the rest of the work I can probably do myself. Has anyone looked into this already or gone through the build? Any help/info would be appreciated. Also looking for a recommendation of a cage builder in the Midwest that is reasonable and has experience w/ PCA rules and Boxters.
Here's a few people who have experience:
Rick DeMan (he posts on this site)
Ernie Jakubowski (he races a Cayman S)
You can also try this site : http://boxcar-racing.com/forum/
For a cage, I have the Safety Devicies bolt-in cage, which is available from Stable Energies.
Hope that helps
You can also check out the boxster spec guys.
Not the same prep, but they have learned quite a bit about racing these cars in the past year or so.
https://rennlist.com/forums/racing-and-drivers-education-forum/373483-boxster-spec-at-laguna-seca-this-weekend-plus-lunch-laps-on-saturday.html
GT3 Track Junkie
1 Post
Rick Deman (Demanmotorsports.com) is building an "F" class boxster right now, not sure but Im sure it could be had quickly enough for you to do the last couple of races of the season.
Thanks for the info. BTW, found some interesting laptimes at Barber that makes me wonder if Boxter in F Stock trim will be competitive http://www.pca.org/clubrace/track_re...ck-Records.htm. F Class record was almost a second a lap quicker than Pobst in a '00 Boxter in GT4S trim... Hmmm. That particular Boxter had ECU and Big Reds up front and may have been under weight for F Stock. Here is a link for reference http://www.thestyleofspeed.com/index.php?showtopic=2379.
Maybe if I blue printed the motor it'll have a chance in F. PCA racing on a budget might not be competitive - who would've guessed LOL .
The early 911s and 944S2 are consistantly at the top of F class. The Boxster has the advantage of mid engine handling. I do not think you can or would balance the engine. Throw aways. The gearing on the BS is a bit off 2 to 3 is sort of in between the torque curve for accelerating out of slow corners. Nice cars. Fun on the track.
lurker , why not buy the D class winning Cayman S, its for sale. Anyway if you build a F class boxster , you can make it win. It depends on the amount effort you put into your racing. Success is earned.
Also, on those PCA results, the '79 911SC is not listed as an F class vehicle on the PCA rules - wonder if the record is incorrect, as that car is now in G class. http://www.44cup.com/1313/pca_rules_2006.pdf
As Ernie mentioned, I believe that a Boxster can be quite competitive and reliable (note the latter) in PCA Stock F. Pick the right car to ensure that you get down to min. weight. My S is still 50 lbs. over ('06 rules), and the drover weighs a tad bit over 150 (too many Krispy Kremes and cervezas).
Let me know if you have any questions. We've learned a lot since starting this slippery slope back in '04....
Primary reason is overall safety. While I am not fast I am going faster and I like the idea of a purpose built cage that is designed to maximize internal dimensions. No complaint on the bolt in I just want a little more. The car has been on a rather severe diet and the addition of the cage and deletion of the soft top and assorted bits will yield additional savings. FG skin being installed for top. Once I pull it out I will maike it available at fire sale $$ for anyone that can find a good home for it, fellow club member did the same for me.
Hupfer's car is an Euro SC, it is in Stock F. Mark is one phenomenal driver, plus that is a well set-up car.
