996 Cup Spring Rates
Until now, I thought I was running very stiff springs 1100/1300 lb-in in my 996 C2 set up like a mini-cup. That was until I burned through my left rear tire. It was rubbing on the top of the wheel well as I bottomed the car out on the right turns in and out of the infields at Pocono. That would mean I was compressing the spring over 3" till it basically was solid. Not a good thing. A 997 GT3, also with a Moton setup and slightly softer springs had the same problem. I was quite suprised to see the cup cars did not. When I got home today, I looked up the spring rates for the 996 cup car. If I do my calculations correct 240/260 n-m is about 2100/2300 lb-in. Does that sound correct? If so, it may also explain why my car seems to have so much body lean and is always carrying the inside tire. Any thoughts?
Not sure how to read the data but they have it listed for the 997 as
Front:
Main Spring 100-60-260
Helper Spring 75-60-43
Rear
Main Spring 120-60-260
Helper Spring 60-60-40
I don't have the 996 manual on this computer to check right now for you
Chris
Front:
Rear
Chris
The 2005 cup manual says:
Front
Main 100/240/60 (240 N/mm)
Helper 75/60/43
Rear
Main 130/260/60 (260 N/mm)
Helper 60/60/50
I'm not sure what this converts to in Lbs. I know the 996 cup isn't very stiff. My 996 stock class car has adjustable GT3 RSR springs that are set at 1600 f/1800 r. It's much stiffer than my cup car.
Front
Helper 75/60/43
Rear
Helper 60/60/50
Originally Posted by amondc
997
Front:
Main Spring 100-60-260 1482
Helper Spring 75-60-43 245
Rear
Main Spring 120-60-260 1482
Helper Spring 60-60-40 228
Front:
Rear
Front
Main 100/60/240 1368
Helper 75/43/60 342
Rear
Main 130/60/260 1482
Helper 60/50/60 342
Front
Helper 75/43/60 342
Rear
Helper 60/50/60 342
Basic Site Sponsor
Basic Site Sponsor
Originally Posted by Greg Smith
IIRC you multiply Nm/mm x 5.7
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
Ok, so 5.7 is the correcttion factor. The N-m vs N-m/mm thing was confusing me. So if I go with Cup rates of 1368/1482 and factor in the additiona weight of my car 3050 vs 2550 (call it 20%) I would see 1600/1800 which is what Jim is running That would be about a 55% spring to weight ratio. Sounds like a plan.
To read the values on the spring (100/60/240), the first number is the spring length of 100mm, the second the diameter of 60mm and the last number is the spring rate or 240nm/mm.
Basic Site Sponsor
Basic Site Sponsor
Ed, one thing also comes to mind, and that is when I saw you scrubbing in your tires at the Glen race, you were actually lifting the front wheels almost a foot in the air when you carved back and forth really hard. It looked quite scary. Going with Jim B's setup sounds like a good plan.
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
Basic Site Sponsor
Basic Site Sponsor
And Larry's seen the back of my car a lot so he knows what he's talking about! ![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
Ho, ho, ho.
You never let me return the favor at the Glen.
