Data Aquisition Question
As the user, you need to be able to get the information out of the data you collect in a manner that is easy for you. Go to the Race Technology website and down the software (it is free) and find some sample data to play with.
I don't know if others allow you to play with the software, if they do, do the same. It is the best way to figure out what works for you.
At the end of the day, they all need sensor input, so don't worry about that right now.
Perhaps the more sophisticated equipment, if it can be used easily may provide additional information that I can use, including analysis of the car setup. If that process takes hours and hours though, I can't see me doing that.
The big issue between higher end and low end, according to a very experienced Engineer who sells and works with ALL of these systems, is that the math capabilities (in the real world, not just building some calculations for demo) are very weak in the low end systems.
If all you want is sector times and video, then why bother with data aq at all? Why not just get a good lap timer system that does sectors, or a pure GPS system and forget the data.
When you cut corners, the analysis is severely compromised. What value is brake data, if you get on/off? You know braking point, but not how hard. You have no idea if it takes you an amateurish 0.5 seconds to get max pressure or a pro level 0.2 seconds. I think you are being very smart in identifiying what you want out of the system and then buying to get that. Too many foks buy a system with little understanding of what it will really do, except that the sales buy (who only sells one of the lower end brands) promised it can do everything that any high end system can do.
Chuck
You can see from the data analysis where the oversteer starts and finished using the lateral G's, MPH graph, and the drivning line below. While this is not perfect it does show the condition. An understeering car will sometimes show a spike on corner entry as the driver tries to loosen the car up by pitching it in the corner. It will show a jump in lateral G upon entry then it drops back down as the driver chases the car through the rest of the corner.
Hope this helps.....still think the orginal poster here would benefit from the basic G2X unit as the others are much more difficult to use.
Someone else in this thread mentioned that you need to be able to analyze the data. My recommendation is to get very familiar with the information available on the Optimum G website. I attended the 3 day Motec shool taught by Claude Rouelle, founder of Optimum G. The class and information provided was awesome. Their technical information on their website is awesome and free. Here is a link. http://www.optimumg.com/ There are some great articles in the old newsletters. It is really worth the time to look at every article even if you've been doing this for a while.
All that said, the import thing is will DA help you improve lap times? I've been able to isolate individual corners and try different techniques with my own driving. I've been able to take off as much as 1/2 sec in a single corner that I thought I was quite good in buy understanding the data. My braking is getting better because the data shows me the effects of late(r) or trail braking. If you're up for the challenge of learning how to analyze your data, then get AIM or MOtec and start learning.
Jerry Austin
84-911 3.6
Bang for the buck (<$1000) it's hard to beat the amount of driver improvement that can be had from an entry level dual axis accelrometer+GPS based system; like the Race Technology DL1 (10hz GPS w/WAAS) and the RacePak G2X (4Hz GPS). What you don't get yet with the entry level products is some of the slick ECU interfaces (but it is being worked on at Race Technology) or data logging rates above 100Hz. RacePak can add up to 12 sensors/inputs on it's CAN-bus based sensor network; the DL1 can add 7 sensors/inputs, besides RPM and wheel speeds which have thier own inputs, and/or one of the optional DASH displays that include predictive lap timing. A lot of the time on modern cars your just tapping into what is already there like the TPS (throttle position sensor) instead of adding a new sensor.
A lot of people place too much emphasis on the line position data from GPS systems because they do not understand the relative and absolute accuracy available. The main advantage of GPS is true speed and beaconless lap and segment times. BTW, GPS speed is combined with accelerometer data to interprolate speed & position between GPS readings. One additional benefit of GPS based systems, that DE drivers might appreciate, is how easy it is to swap between cars and still get some basic data; without GPS you just can't do that.
I'm looking forward to trying out the AIM GPS module as it becomes available this spring (just announced that it's finaly done at PRI). BTW, Motec sees the benefit too and has been testing their 20Hz GPS module all year; AFAIK it is not yet available for sale. I was sold a long time ago on the benefits that GPS adds to data acquisition, no matter what brand you are considering.
All the brands work with Trackvision.
Lot of information out there. Google is your friend.
Jeremy Lucas
FastTechLimited.com
It does get expensive when you add in sensors but for RPM and GPS, Gs, speed, it's cool also and stays portable.
many thanks
JM
In terms of what I was trying to show folks here is that an oversteer condition shows itself with a GPS based system. The upper graph showing lateral G load and MPH shows an increase in G's and a lose of MPH at the point where the cursor is. The lower right graph which is magnified shows the driving line which takes an abrupt right turn not because it is a turn but because the car is over steering. Drinving line and car attitude change which is picked up bythe GPS based unit. The graph on the lower left shows the overall track position.
While this is not a definitive method to tell when a car is over or under steering all the time (smaller correction of the chassis) it does show that these "less expesnive" units can display some of the characteristics of the much more expensive units.
I know that the resolution of the pic I posted might be hard to see though it is easily seen when using the analysis software directly.
Other interesting things I note in that trace... in Turn 5-6, 180 deg LH-er, seems like you're double-apexing it. That's probably appropriate, particularly in a race situation, and I assume the course is basically flat and level since it's a roval... but looking at your speed and lateral combination there, I gotta wonder if you could carry more speed in there - the reason why is it seems like your lateral drops off a bit after turn-in, then builds to make the second apex. I'd be interested in seeing what your steering input is there too.
It's also interesting - though not 100% clear at this level of resolution - that you appear to pull some opposite lateral for quite some time exiting that corner. Does the track actually curve a bit to the right there? Again, kinda hard to tell; I'd be wondering if there were a way to straighten that out, though if it's much of a RH bend, you could end up sacrificing some track out and overall speed.
Turn 7-8 is a little perplexing; entry seems quite agressive/good, but after the first RH (not the king in your braking zone, but the first tight radius) and before the 2nd tight RH turn there seems to be a lull in the action; basically 0 lateral, yet the acceleration seems weaker than out of the hole in the first/slowest part of the turn. Is that a shift point, on track-out after the first turn? Also, your lateral on tracking through and exiting 8 seems a bit lower than the slower turn - perhaps the line could be more agressive here, you could push the car harder?
Finally, the esses leading onto the banking... Looks like you're having no problem getting the car to turn well going in - seems like you're getting lots of lateral on those first two. But I have to wonder, from looking at the speed trace, if there's a combination of line and setup that could improve your exit onto the banking - which would no doubt reap huge benefits in lap time - because of the substantial amount of speed that has to be taken out of the car on entry of 10. Yet at the same time the speed is being killed off, the laterals achieved are declining - only 0.8-1.0g vs. the full 1.4 or so on entry of the esses. Perhaps this is just another example of fast-in, slow-out? Because again on exiting the banking, in what should be a single, presumably increasing-radius LH turn, I see two distinct peaks on the lateral, before it tapers off on the banking and you're just cruising.
HTH, feel free to rebut!
We'll all be able to see more if you increase the resolution...
Open for any suggestions and can post more detail of any or all turns however it would be much easier if you had the software and I could send the data
