DE Run Groups
DE Run Groups
I am wondering if throughout PCA or at least throughout a region, run groups map 1-1. For example, should students expect white or black groups in one chapter/region to be comparable to others within the PCA world.
And if they are not, if you are promoted to a higher group in one chapter's event, is that valid in another chapter's event?
Any thoughts from our instructors?
Thank you,
Thank you,
Still plays with cars.
From what I have seen, the performance of drivers in supposedly equivalent run groups is quite variable. The most consistency is usually in Red,but even there the differences can be occasionally be striking.
Originally Posted by Willard Bridgham 3
White run group is probably ther only run group about which you can generalize....they no longer have an instructor and get the red mist.......
The white run group can be interesting because it seems to be the group that contains the greatest variety of experience and skill levels, which really has nothing to do with red mist. You have some drivers who belong in the advanced groups at one end of the spectrum, and other drivers who have just squeeked out of the beginner groups. Put them on the track together without instructors and you are bound to have a few interesting moments as one driver's fast is another driver's sunday driving, not to mention that what is driving with confidence to the advanced drivers may appear to be unnecessarily aggressive to the less experienced drivers.
In order to get point bys in white while driving a n/a 944, I had to be far more aggressive than I have ever had to be in the black run group, but my aggression had nothing whatsoever to do with red mist. It was a necessity to get people driving cars with far greater horsepower to put their left arm out. The more uncomfortable I made them in the corners, the less likely they would stick their arm out the window and then out drag me down the straight. I found that there was a direct relationship between "lack of comfort" and "degree of lift" on the straight. Of course, I didn't do it the first time I came up on someone, but after I lost a drag race, I assumed my intentions had been misunderstood. Since it is white group, other drivers do not always assume that their co-drivers are peers or better. In the advanced groups, there seems to be an assumption that most people belong there, and if someone doesn't, everyone seems to know that too.
The other factor in white is that the members of the white group tend to change more frequently. When you run with basically the same group of drivers, you get to know them and that makes everything easier. When the group of drivers is always changing, it takes time for people to get used to the styles and skills of their fellow run group drivers. By the second or third day things calm down.
I am in black group, but I was promoted at the beginning of this year so I remember very well what it was like in white. Black is so much easier . . . .
I have found that the experience level of the various groups is dramatically different between regions. From Potomac, I don't feel out of place in any other region's equivalent group. In some regions, I feel that I could easily move up a group (and actually should).
The move is only valid for that region, each region is it's own entity. "Usually" your home region's group is the one you go by when registering elsewhere...
Todd!! Out-typed me again!
The groups vary from region to region based on their DE program. I think you'll find students are in the lower groups longer in the larger regions like NNJR, CVR, Potomic where they have well defined criteria for advancement and usually 2 instructor signoff for advancement. In the smaller regions, the programs are less well defined and they tend to get people from other regions in the program so there isn't much documentation as people come in and out of the program. In our HV Region for instance, we have only about 10-15 members at our track events, so we have another 50-70 drivers from neighboring regions. We also combine green and yellow so in effect have 1 novice group.
So, yes, it does vary.
Thank you,
Thank you,
Run groups are NOT equivalent from one club to another. Heck, not even from one DE to another within the same PCA club. Certainly, an effort is made to classify drivers according to experience, but the biggest factor I've found has to do with distribution of the participants.
Let me give you some examples. My wife, an absolute novice, obviously went to the "Green" group (Class D) first time out. This was a one day event. On her second outing, they put her in the C group, simply because there were a lot of "never been to any track" drivers that occupied the D group. She still did fairly well, eventually caught on, but she spent a lot of time watching her mirrors and giving point-by's the first few runs.
I ended the 2004 season 2 years ago in the A group. Did well, had a blast. Next season, spring 2005, there were a whole bunch of race drivers wanted to get in early to test and tune and what not. Result? I was now back in B group for the actual DE due to the exceptionally large numbers of experienced race drivers who signed up. In that B group with me were a lot of drivers who actually had more experience than I. I spent the rest of the year and this year in the A group, but there may come a time again when a large number of drivers more experienced than I show up and I will again be relegated to the B group. It may or may not happen, since most of the drivers with more expererience than I are now racing and go to different events altogether.
Rennlist Hoonigan
which cost no drachmas
The groups really differ. Depending on the region, they may have different criteria. Overall, I think the driving experince is pretty similar, but the cars are not. In most regions I run in Red as an instructor. At some events and in some regions, I run in black as an instructor becuase of the speed differentials. I'm no match for cup cars.....
Matt
Matt
Basic Site Sponsor
Basic Site Sponsor
I think that the white (middle) group has the most variation among clubs. It really depends on how many drivers are moving up the ladder too. The differential in ability and lack of instruction in the white group is one issue that we at Riesentoter are addressing. We have had a white group class for the last few years, taught on & off by various instructors, but for next year I am planning with the new CI to take the white group "under my wing" and have regular classes at each event, plenty of available instruction and more dialogue between the drivers. This can help the new white drivers get acclimated more quickly, and identify which drivers should move to black due to ability, and not just seat time.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
Larry, that is good to know. With your 40 years of experience I hope the class is open to everyone.
Thank you,
Thank you,
Most PCA regions have multiple groups with varying skills that may approximate the groups you are familiar with. Most regions will have similar entry level groups and top "instructor" run groups. The run groups inbetween will vary depending on how many groups that PCA region typically has. Some run 5 or 6 run groups and some just 3 (I have seen even just 2 at select events).
If you are signed off solo in one region that may not mean much in another region especially if you have never driven that particular track. If they use the same track then you probably can go into an equvalent run group as this sort of thing is probably common.
Passing zones and rules may vary from region to region as well. Always check with hosting region to understand how these work.
Thank you so much to all for replying and enlightening a greener like myself. I think it is at least an interesting discusion. I have heard that PCA has some effort already in place to somewhat standardize instructor training, which invaluable I believe.
The question in my mind also is should we have an effort in place, similar to what Larry is trying to do with the White group, to have common and may be region-wide or nation-wide student skill evaluations and run-group standardization. This may not be feasible for the Black and Red run groups (based on Palting's feedback), but probably would be quite useful in lower run-groups, or would it actually be of any use and the current systems is good enough.
Obviously, this is not about the "badge of honor", but more about safety and value offered by the DE. Additionally, I think the run-group classification for students should probably be done per track vs. just general skill level. I, for example, now feel very comfortable with any configuration of VIR but totally uncomfortable with Summit Point, Watkings Glenn, Mid-Ohio, Pocono, etc. But I don't think it is feasible to rate someone per track unless the definition and qualifications of run-groups are standardized at least acroos a region.
I might obviously be totally off base here as I have very limited experience with DEs. Again, thank you for all your opinions.
I totally agree with Matt. Since I drive an under powered car I sometimes get moved to black even though I am an instructor and have a lot of seat time. However, HP sometimes beats out seat time. - Jay
