Trail brake versus early throttle
I was taught trail braking at skip barber, but during my last outing in my 911 SC G-class, it felt better to get on the throttle before turn in and use the throttle to contol car rotation. It seems like the two basic recipes for speed are a) late braking with trail braking after turn in, versus b) slightly earlier braking, downshifting and back on the throttle before turn in. Trail braking felt great in the mid engine open wheel cars at Skippy's, but the early throttle felt much better in the 911. What's the party line if any?
It really depends on the corner of course. In general, my exit speeds in medium to high speed corners are better the sooner I get on the gas. This is often very soon after turn initiation and way before I hit the apex of the corner.
What really matters is getting the car to do what you need it to do. If you have too much understeer on corner entry, you would want to trailbrake more. The brakes (besides the basic slowing) are one of the tools to keep the contact patch balance to where you need it to be at any given time. The best way to find out your answer is to hire a coach and have him/her drive your car and see what they do.
Basic Site Sponsor
Basic Site Sponsor
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
Whether you trail-brake also depends upon the handling characteristic of your car as well as the corner.
In a pretty neutral car, you really don't have to trail-brake much because the front tires are biting without weight transfer caused by trail braking....in a rear-engined car, trail braking loads the front tires so you can turn in.
There are corners where I trail-brake to rotate (long ones as already observed), but not many.
It sounds like you are over braking the corners and giving up entry speed. Carry some brake pressure after turn-in and get on the gas after the car settles.
You're clearly overbraking. If you're doing it properly any touch on the throttle before apex WILL throw the car out of the line in understeer (specially on a road going 911) I say you're probably going in 2 or 3mph too slow.
Trail braking is a very usefull tool on 911's or front-engined/FWD cars were the rear is difficult to rotate. On slow to mid speed turns TB reduces understeer dramatically and in mid speed corners it settle the car by distributing the loads better increasing the speeds on turn in AND through the corner.
The 100% use of grip rule applies: brake as hard as the traction allows you to (in a straight line) but as soon as you start to turn the wheel for turn in you MUST reduce brake pressure accordingly because you're making use of the tire's lateral traction now and both forces combined will obviously not exceed 100%.
I don't which 911 you drive where the rear end is difficult to rotate. It sure does not take much for my G racer. I found I could easily over rotate the car with trail braking, and again, I found the car much more stable in medium to high speed turns when I got on the throttle before turn in. As suggested previously, in tight turns at the end of long straights, late braking and trail braking would seem to be the best technique to carry more speed into the corner and get the car rotated.
Basic Site Sponsor
Basic Site Sponsor
I concur with both of Larry's posts here. This is what I teach.
As I stated before, traibraking is a technique to keep the contact patch where you need it given the circumstances. There is no definite rule about when to use trailbraking. Throttle, brakes and steering are the inputs at your disposal and you need to first realize that those three inputs provide more than just their primary objectives. They are also used for car balance and keeping the contact patch maximized so that your friction circle is as large as you can get it in the direction you need it to be.
BTW, Larry's advice is always (usually) spot on.
