Ultra-Shield Rally seats install
After years of talking about getting proper seats and 5pt harnesses I finally got off the side lines. I decided to go with the Ultra-Shield rally aluminum race seats, 16" 10degree layback for the driver and 18" for the passenger (you never know what size or shape a passenger/instructor may come in.
The belts are Schroth Profi II ASM FE which can be used as 4,5 or 6pt and are street legal.
![](http://forums.rennlist.com/upload/img_0327front.jpg)
![](http://forums.rennlist.com/upload/img_0328left.jpg)
The old and the new
For mounting I went with Kirkey Universal Seat Brackets and Summit Universal Dual Locking Sliding Seat Brackets. They were all bolted to the seats with carriage bolts and an additional washer on the inside.
To adapt the sliders to the stock mounting points I used 1/8th x 1.5 inch steel plates and 1 inch and 2 inch plate for the passenger’s side. The sliders had mounting bolts for mounting to the floor. The rear ones were drilled out and on the drivers side they aligned with the first of the two rear bolt holes. The front ones were left and used to bolt it to the plate. With the passengers side the inboard rear hole aligned but the width of the seat the 2 inched were needed on the out board side were required to make up the difference. Ideally a 2.25-2.5 inch plate would have been ideal.
First fitting.
Mounting of the belts was straight forward. The lap on the outboard side was bolted to the stock mounting. The inboard side required drilling and placing a nut plate on the back side of the tunnel. The sub strap was bolted through the floor up front and through a stiffening ridge and another nut plate. The shoulder straps are mounted to a John Hajny bolt in rollbar.
Final results.
I am real pleased with the seats. The only cravat is I'm 6 foot and the 16 inch seat could stand to be a bit longer in the torso. The 18 is a better fit that way but too wide. I believe for more $$$ Ultra-Shield would build one to my specifications.
Everyone asks how much, so....
Metric Alan wrenches
Hacksaw - sawsall optional
Drill - Drill press optional
Dril bits upto 7/16
Grinding wheel or file
Small file
Metric socket set
Plyers
![](http://forums.rennlist.com/upload/img_0333showtime.jpg)
![](http://forums.rennlist.com/upload/img_0330back.jpg)
The old and the new
![](http://forums.rennlist.com/upload/img_0385oldnew.jpg)
![](http://forums.rennlist.com/upload/img_0388closeup.jpg)
![](http://forums.rennlist.com/upload/img_0389hole.jpg)
![](http://forums.rennlist.com/upload/img_0404barecar.jpg)
![](http://forums.rennlist.com/upload/img_0406seatplatescar.jpg)
![](http://forums.rennlist.com/upload/img_0413seatbottom.jpg)
First fitting.
![](http://forums.rennlist.com/upload/img_0408firstfit.jpg)
Final results.
![](http://forums.rennlist.com/upload/img_0417installed.jpg)
Seat $220 each
mounts $39 set
sliders $25 set
belts $245 set
sub $15 each
nut plates $5 each (Note: belts came with one each)
flat stock $25 total
misc bolts, etc. $18 total
Tools mounts $39 set
sliders $25 set
belts $245 set
sub $15 each
Dril bits upto 7/16
Small file
Metric socket set
Plyers
It's interesting that the sub-hole is so far forward on the Ultrashield. This may need to be addressed if you ever go racing. It's recommended that the sub strap lies against the body and both keeps the lap belt from riding up and the body from sliding under.
Nice looking install!
Just know that if you are doing DEs, you may not pass tech with the way you have installed these seats. I say "may" as some techs overlook many things, but there are some that don't. Aluminum seats must have at least a back support to the roll cage (bar in your situation). Aluminum seats are really not designed to bolt to the floor as in most all racing rules they need to be mounted directly to the cage in at least four points.
(I know, I'm being a *****...
). Not sure why you went with the 5 point as 6 point may become the rule soon in all clubs.
Anyway, they look good. Just know what you have and what the pros and cons are in having them.
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
What club race or DE groups require aluminum seats to be mounted to the cage in four places? I don't believe I've seen that rule in the clubs that I run with, although the seat will need a back brace since it isn't FIA approved.
I have 6 point belts, but I haven't heard or read anything about 6 point becoming mandatory. Fortunately for Neil (the original poster) he can get 6 point sub-straps by Schroth that are compatible with his belts for under $20 each - so if the rules ever do change he doesn't have to buy new harnesses.
Enjoy the new seats - they will feel way better than the stock seats when you're driving hard.
I second what onasled said about the back brace. You have a major safety issue with this one. Contact Ultrashield and ask them if the seat can be used without a seat back brace. Even if they can you want to seriously consider a seat back brace.
Keep in mind you have a 1 1/2" or 1 3/4" bar just inches from the back of your head/neck/spine. Not to get gory but if the seat back gives way then you have an immovable "clothesline" right behind you.
chrisp writes:
Hey Riff. Been a while. I wondered why you hadn't been to any events recently. Been missing the competition.
onasled writes
....... Aluminum seats must have at least a back support to the roll cage (bar in your situation). Aluminum seats are really not designed to bolt to the floor as in most all racing rules they need to be mounted directly to the cage in at least four points.
(I know, I'm being a *****... ). Not sure why you went with the 5 point as 6 point may become the rule soon in all clubs.
I will check with Ultra-Shield.
On the sub strap, in hind sight I don't know why I didn't get the 6pt while I was at it.
My current configuration is fine for AutoX and DE but if I decide to race I will need to add a proper roll bar/cage, camber plates, bushings, control arms, shocks, springs, coilovers....... A back brace is the least of the potential expenses.
Neil;
Compared to some of the junk I see, your instincts are WAY better than most peoples. Did you do that all yourself? You followed a very similar system to how I usually do such installs. I just did one in a Club Race 944T. I have to pull the driver seat and cange the angle. I'll post some pics when I get to it next week.
A few points for all:
1) Single subs go 10 degrees FORWARD of the imaginary spine line, NOT back snug against the body. Think about where that "snug" strap would be!! The ASM feature does mitigate the single sub deficiencies somewhat, but does not make up the advantage of a Schroth "T-bar" double sub. The best setup is non-ASM with a double sub, but it aint street legal either.
2) The Redline Roll Bar has more natural protection against rearward projection of the seat than most cage/bar designs. There is a vertical tube that sits right behind the headrest, quite by design. A seat back brace is not mandatory in any DE group I know of, but is not a bad idea if you plan to take chances. The minimal shoulder support of those seats will mitigate seat twist to some extent, but a brace still helps in the rearward direction.
3) I use the same tracks as you (JAZ Products). I also pop out the studs that come in them and bolt them to the floor. However, I use 3/16 steel instead of 1/8, as I don't feel the smaller size is nearly strong enough, PARTICULARLY if you are doing a "sandwich" type conversion bracket (track-to-plate, plate-to-floor, all bolted) like you have. I take this steel and make short "extension pads" that go under each end of the track to interface with ALL the floor holes, and then weld them to the tracks. I would urge you to reconsider this material spec.
You have done a fine job overall. If you're looking to apprentice as a fabricator, give me a shout!
Originally Posted by RedlineMan
Neil;
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
![](http://forums.rennlist.com/upload/submounting.jpg)
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
That is part of the reason I ran the plates full length between the mounting holes and plan to weld the rails to the plates, full length beads. That way the longest unsupport section is only 1.5 inches. That is the one in the pic of the passengers seat bottom above.
When I take them out to weld the tracks, I can cut out a couple of 2-3 inch tabs and have them welded on the bottom of either end of the plates to make 1/4 inch. I have plenty of left over stock.
Originally Posted by N_Halbert
Now, would you have an economical upgrade available?
$70 - $140 seems like a lot for a fairly simple piece. I may have to save the money and put it toward a welder of my own.
Oh don't rain on my parade. That's how I'm able to justify new tools and neat stuff. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I was at HMS Motorsport today and they will let me swap the single sub for a 6pt.
If I do go with a seat back brace, what about the type of mount to the seat? I would think the style with a flat 1.5x5 inch bar could be an issue if you do go in backwards. Seeing how Al will bend and absorb the impact, the bar will end up punching you in the back and the seat will deform around it. So, is a larger triangular style better?
Hey;
I'm not sure what you are looking at in terms of a brace. Most people use the Brey Krause unit. It would be tricky to get mounted to your Redline Rollbar, but I'm sure something could be done.
Anyway, here's a picture of how I do my slider mounting conversions. You can see the heavy gauge extension pads welded to the bottom of the slider.
![](http://www.redlinerennsport.com/06SubBrktBeltedBlue.jpg)
